Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 01-15-2006, 08:40 PM
NoXferCase NoXferCase is offline
Question B15 -> Jdm B15
OK, I realize this is not your "bread and butter" motor swap, but this is an old "tired" '92 civic that my daughter is going to inherit.
The OEM B15 got blown up when my wife saw the temp gauge pegged (blown water pump) and drove it home anyway. She didn't want to walk!
I bought a (cheap) JDM B15 (both engines are the 16-valve variety) and swapped. Unfortunately, the driver-side motor mount is wrong. The OEM engine bracket has two posts that run parallel to the fender. The JDM engine bracket has the same two posts, but they are angled at about 45 degrees.
The guys at the local "ricer shop" say you can't buy a JDM motor mount. Partial disassembly of the old motor seems to indicate the engine bracket is actually part of the casting for the block.
Is there a "simple" solution here????? Gawd, I hope so!
Thanks in advance.
Mike
Old 01-15-2006, 10:46 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: B15 -> Jdm B15
first off its a D15.....and i don't know the answer, but why did you make 3 posts for the same thing??
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-16-2006, 10:46 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: B15 -> Jdm B15
what d15 is this?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-16-2006, 09:09 PM
Re: D15 -> Jdm D15
Originally Posted by superbluecivicsi
what d15 is this?
OK, yes it's a *D*15. My bad!
If I posted 3 times, I apologize. The first couple of times I tried to post the board told me I wasn't signed in anymore. So, I signed back in and tried again... and again...
I'm not fluent in all the motor codes, but it's a 1.5 liter out of a 1992 4-door Civic LX (non-VTEC), has 16 valves and made about 102 hp from the factory. The JDM motor is visually almost identical right down to the "16 valve" on the valve cover.
Hope this helps!
Old 01-20-2006, 12:37 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: B15 -> Jdm B15
Pull off the timing belt cover and you'll see the bolts, remove it and get one that works, simple.
Old 01-20-2006, 12:49 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: B15 -> Jdm B15
holy shit it's OG jcrx
Old 01-20-2006, 12:58 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: B15 -> Jdm B15
Yip, all the mounts are just bolted to the block.
Im surprised the mounts are differnt though, Im guessing the JDM D15 didn't com e out of another EG Civic.
It might be out of anything from a CRX, to an EK Civic to an Integra (the last two would explain the odd engine mount) .
