Old 01-15-2006, 06:35 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
pulley?
hey, so my car is geting look at right now about my tranny mount, so i can not look at it, but here is my question. What is the pulley under the ac one? it is right under it, it is making a squeek noise and i need to pelace it, just wanting to know what one is it? Oh ya the car is a 92 camaro r.s 305 tbi automatic.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 01-15-2006, 10:59 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: pulley?
its your smog pump. you can take it out if you dont have any emissions testing. Otherwise go to thirdgen.org and dig around the classifieds for people parting their cars or post in the parts wanted section. There may even be someone here with one. Are you going to put a polyurethane tranny mount in as a replacement?
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 01-15-2006, 11:24 PM
97cavalier's Avatar
Re: pulley?
how much more is the mount? and where do i get them?, just a auto parts store?
Old 01-15-2006, 11:28 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: pulley?
i thought the tensioner was under the ac
Old 01-15-2006, 11:29 PM
97cavalier's Avatar
Re: pulley?
and about the smog pump, if i remove the pump, what about that pulley? do i have to get a diffrent belt now?
Old 01-15-2006, 11:34 PM
Re: pulley?
if you could find a speed shop locally you could get one there. Otherwise go to http://www.jegs.com/webapp/wcs/store...0059&langId=-1 and order one. Small stuff like that usually ships pretty quick. Did your guy look at the mount? If you get under the car and gently push up to the transmission and see if the mount is split. The same thing happened to me in my car. Any time you gave it some gas in a low gear there would be a loud thud. Scared the crap out of me. Changing the mount is pretty easy if your familiar with working on cars.
Old 01-15-2006, 11:38 PM
97cavalier's Avatar
Re: pulley?
that is EXCATLY what mine is doing, at like 40 and under in a low gear or when i torque it it sounds like the tranny just went threw the damn floor. I am going to have the guy look at it to make shure that is what it is, and if so, i will do it myself.
Old 01-15-2006, 11:39 PM
Re: pulley?
my tensioner is to the right of the a/c unit. is it a big pulley or a small pulley?
heres a link with info about taking off the smog pump.
http://www.thirdgen.org/newdesign/tech/serpentine.shtml
there is a lot of usefull info at that site.
Old 01-15-2006, 11:44 PM
97cavalier's Avatar
Re: pulley?
the puley i am talkin about squelin, it is down and a little to the right of the a/c, it is a meduim size puley.
Old 01-16-2006, 12:08 AM
Re: pulley?
is the pulley in that picture?
Old 01-16-2006, 12:10 AM
97cavalier's Avatar
Re: pulley?
that is not the same motor as mine, i have the tbi, and there is another pulley under the a/c.
Old 01-16-2006, 12:15 AM
Genopsyde's Avatar
The President
Re: pulley?
it's the smog pump then.
Old 01-16-2006, 12:17 AM
97cavalier's Avatar
Re: pulley?
ok, but if i remove it, do i have to get a diffrent belt? bucause that pulley won't be there any more.
Old 01-16-2006, 12:18 AM
Re: pulley?
different motor same serpentine setup. In that picture the smog pump has been removed. i just wanted to make sure it was the smog pump we were talking about. In that link I gave you there should be the belt size that you would need if you removed the pump. When you remove the pump the pulley comes with it as well as all of the smog lines that clutter up the engine bay.
Old 01-16-2006, 12:20 AM
97cavalier's Avatar
Re: pulley?
i think i will just get a new pump, because i have emisions here, but is emisions only on 96 and up?
