Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-15-2006, 05:03 PM
Techventure Techventure is offline
Question 92' Camry Distributor Rotor
After replacing belts, plugs and wires, dist. cap and rotor and going thru a learning curve of setting the cam timing on our V6 1992 camry, I finally got her idling at 750 rpm's and running like a new engine.
My wife was driving home and the engine died after she heard what she describes as a low "POP". I had the car towed home and started checking and found the rotor had come loose in the dist. cap and stopped the engine.
The rotor is only held by two small screws in the end of the distributor.
What is the best method to ensure this does not happen again ?
Use a loctite material on the screws ? Any other suggestions ?
Thanks.
Old 01-15-2006, 05:26 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool Re: 92' Camry Distributor Rotor
Pretty much.
Permatix & Loc-tite both make a tread restorer. Try that if yous tripped it out. Otherwise good luck funding a 3vz-fe dizzy. There are not that many non JDM 3vz-fe's around.
The autostore-aftermarket dizzys are like $150-200 parts. God forbid you had to go to Toyota/Lexus!
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 01-15-2006, 05:36 PM
Thanks Toyrme,
Threads look fine. Screws just turned and fell out. I can put new screws in i just want to ensure they stay tight this time.
