Old 01-15-2006, 01:58 PM
mrfirebird mrfirebird is offline
belt tensioner
can you just replace the pully on the belt tensioner or do you have to replace the whole assembly ?
01 F150 Supercrew 4X4
01 F150 4x4 regular cab
67 Honda Superhawk CB77
07 Honda Civic
Old 01-15-2006, 02:11 PM
old_master's Avatar
Advisor/Moderator
Re: belt tensioner
Some manufacturers offer just the pulley & bearing for the tensioner. However, if the tensioner has a substantial amount of miles on it, you're better off replacing the whole tensioner assembly and be done with it. Replacing only the pulley is an inexpensive, easy way to repair it. Replacing the complete tensioner assembly would be considered doing the job right.
Old 01-16-2006, 07:05 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: belt tensioner
I'd have to agree with that. The pully most times is only a couple of dollars less than the entire assembly.
Old 01-17-2006, 08:21 AM
herkyhawki herkyhawki is offline
Re: belt tensioner
I would replace only the pulley. It is very easy and the last one I got was only about $8.
Old 01-18-2006, 02:43 AM
joblo33's Avatar
joblo33 joblo33 is offline
Re: belt tensioner
Ditto on just the pulley. Is it squeeling? My '93 s10 was squeeling and I replaced just the pulley. It went back to normal and has stayed that way ever since. And the pulley was cheap .
Eric
Old 01-19-2006, 12:15 PM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
Re: belt tensioner
had the same problem, and simply replacing just the pulley did the tricks.
$10 + tax
1997 Blazer LT 204k miles, 4X4, BF Goodrich AT's, 2 Pioneer 6x9's, 12" IMPP subwoofer with 1000watt Pyramid Amp. CAI.
Old 01-19-2006, 03:59 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: belt tensioner
I have to agree in replace the whole assembly. It only cost a few $'s more. If your pully bearings are bad, then the spring tension has got to be weaker. Just replace it. You'll feel better.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
