Old 01-15-2006, 01:24 PM
seasonalskier2006's Avatar
seasonalskier2006 seasonalskier2006 is offline
Send a message via AIM to seasonalskier2006
Question 94 Wagon Screaching
I go to school every morning and i always start it up and while it is warming up i hear a loud humming/screaching under the hood and it will stop for a minute or two then it will go for another minute making the noise then it will stop and wont start doing it again till next morning. it doesnt happen to me when i get out of school either, so i am wondering what it could be. My only thought is a belt is loose or needs repair, am i on the right track or way off?
Old 01-15-2006, 07:37 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 94 Wagon Startup
Do you happen to have the defroster or air conditioning on when you start it in the morning? If so, you are probably correct that the noise is a belt. Well, you are probably correct that the noise is a belt anyway. If you have the defroster or A/C on though, that would help explain the cyclic nature of the squeal. Defrost will also engage the A/C compressor (to remove the humidity from the air) and assuming your A/C system is properly charged and the ambient temperature is above freezing, the added load may be causing your belt to slip and squeal.
Inspect the idler pulley and self tensioner for wobble and bad bearings. If they look fine, then replace the belt. I'd suggest using either a Kelly-Springfield or Gates belt. From my experience, Dayco belts tend to stretch and squeal and Goodyear belts often times are noisy.
-Rod
Old 01-15-2006, 07:39 PM
thanks for the advice rod i will try that
