Old 01-15-2006, 12:20 PM
dolfins1a dolfins1a is offline
94 SS running really rough when A/C on
I just recently had taken it in to have a computer diagnostic done by the dealer. They said the problem was the spider injection. I replaced it myself with the new nut kit and that made some improvement. It still has a slight miss to it at higher speeds, at lower speeds 40mph or less when you let off the pedal the engine revs up a couple hundred rpms. When the A/C is on it feels like its missing severely and running really rough. Anyone else experience this problem?
Old 01-16-2006, 07:21 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 94 SS running really rough when A/C on
When you replaced the CPI and the Nutkit, did you pull your plugs? Typically when you have a lot of fuel dump like that the plugs get fouled and the EGR gets clogged up. So replace your plugs and clean the egr and see if that helps.
Old 01-16-2006, 06:55 PM
I failed to mention before that I also did a complete tune up after the change and cleaned the EGR because I thought that it might have been one of the problems. It still hasn't made no difference. Thanks for the reply.
Old 01-17-2006, 04:43 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
have you tested your coil? battery and charging system? any of these will cause it aswell.
Old 01-17-2006, 08:03 AM
rlith's Avatar
Check that all your vac lines are connected properly and that there are no dry rot or cracks in them. And when you did your spark plugs did you make sure that they were all gapped to .45?
