Old 01-15-2006, 12:15 PM
tykrz's Avatar
tykrz tykrz is offline
Fix for steering clunk
Here's the fix for steering clunk. Unfortunately, you have to pay for it as it isn't from GM.
I listed the link below:
http://www.borgeson.com/TruckProductChevy.htm
Old 01-15-2006, 03:21 PM
kmschna kmschna is offline
Re: Fix for steering clunk
The Gm Lube Kit worked nicely for me.
Old 01-15-2006, 03:34 PM
tykrz's Avatar
yeah that fixes it for 15000km then it clunks again when the grease thins and seeps out, so you bring it back and they then put in an upgraded shaft and in another 30000 km it clunks again at which point GM says its normal and won't cause any adverse or saftey problems, but they will regrease again if you want but you will have to pay for it.. At least thats my experience with this issue. I've got one ordered up already and they guaranteed it will fix the problem forever.
Old 01-18-2006, 03:02 PM
TwentyPints TwentyPints is offline
i got mine replaced at 25,000 km under warranty.
K&N High-Flow Air Filter
Flowmaster 40 Series Muffler (Dual Out)
Vibrant Performance Exhaust Tips
BFGoodrich Mud-Terrain T/A LT265/75R16
Clarion Pro Audio System
Old 01-18-2006, 05:05 PM
Smile Re: Fix for steering clunk
Spend your money as you like, of course. But in less time than an oil change, an once of grease(reuse the kit) and a chance to reaquaint yourself with your truck, I can certainly regrease it every 15K.
Old 01-18-2006, 05:10 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Well has anybody figured out a way to put a grease fitting on the dan thing?
MT
MT
Old 01-21-2006, 10:32 AM
fire24resque's Avatar
fire24resque fire24resque is offline
Maybe the lack of puncuation confused me but are you saying that the replacement shaft only works for a little bit? I just replaced the pitman arm and idler arm on my truck (stupid things were worn out already, my tires were feathering on the outsides so I jacked it up and had all sorts of play in there) and it tightened up my steering like you wouldn't believe! It almost totally removed (or hid) that steering column clunk. I can still feel it here and there, and I was thinking of having it done, if it lasts.
Thanks
2001 Silverado 4x4 - 4.8 V8 - Hankook Dynapro ATm RF10s, 265/75/16
K&N FIPK - Flowmaster 50 Series 3.5" Duals
4-Headlight Conversion Kit - Billet Grille
90 Watt Nova Strobe Pack
2.5% Limo Tint -
Check Out Pictures and More Here
http://www.cardomain.com/ride/2131569/1
Old 01-25-2006, 11:12 PM
RyAmber RyAmber is offline
Forget greasing the steering shaft, only a temporary solution..Just spring to replace the steering shaft only about 75 bucks..I did it recently, clunk is gone and steering is tight as ever..Was done by dealer for this price as well..
Old 01-30-2006, 04:19 PM
Can anyone answer me this question....
If I get the replacement steering shaft part installed in my truck, would that in any way throw my alignment out of whack? I just replaced the pitman arm and idler arm on my truck and it knocked my toe alignment from here to Japan and I just paid to have everything put back where it should be. My next move was going to be getting the replacement part but if it's going to throw my alignment off it's gonna wait!
Thanks
2.5% Limo Tint -
Old 01-30-2006, 05:08 PM
MT-2500's Avatar
AF - Advisor
No problem there.
But one word of caution. Lock your steering wheel straight ahead and keep the wheels straight ahead when you install it.
If you do not or turn the steering wheel when it is unhooked good by clock spring for air bag .
MT
Old 01-31-2006, 07:18 AM
pies pies is offline
just a question, mine only seems to clunk when it warm out. if the temperature outside is below 0 celcius or 32 farenheit it does not clunk. is this the same problem or should i be looking for something else.
Old 01-31-2006, 08:04 AM
I talked to a friend of mine that I haven't seen for a few years last night and found out he works for a GM dealer and can get me the replacement shaft for his discounted price. He said he got one for his 99 Silverado and his parents 02 tahoe and he installed them in each in under 10 minutes in his driveway. He said neither vehicle has had a clunk or vibration since. Looks like I got lucky here!
2.5% Limo Tint -
Old 03-30-2006, 04:41 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Is the steering clunk a series of pops and thumps when turning the wheel?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 03-30-2006, 07:11 PM
jasonb01 jasonb01 is offline
My truck makes a knock on the drivers side. Mostly when I hit bumps. Is this the cluck everyone talks about or could that be the suspension?
Old 03-30-2006, 07:52 PM
2000CAYukon 2000CAYukon is offline
For me, it only happened when I was turning into a driveway or going over a bump while turning. It was a clunk that you could feel in the steering wheel. At first I thought it was suspension but could not find any worn out parts. Eventually found this forum and bought the lube kit to fix it. So far, it has not come back.
//2000CAYukon
