Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-15-2006, 10:47 AM
fuba fuba is offline
92 Marquis problems
My 92 Marquis starts fine, idle is great and smooth. after a few miles, the car will buck slightly. If I get on the gas, it will stop.
I recently had the car to the shop where they put in a used MAP sensor.
The check engine light pops on, but then goes off. Does the 92 store that code?
Any have any ideas of whats going on? Could it be the trans?
Old 01-16-2006, 02:21 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: 92 Marquis problems
My 91 had 2 problems with bucking, bad plug wires and later on a bad MAP sensor. Codes should be stored if the CEL light came on.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 01-17-2006, 07:17 PM
How long are spark plug wires good for? Mine are two years old.
Old 01-20-2006, 08:10 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Spark plug wires should be checked/ changed right at 2 years or around 30,000 miles, so it'd probably time to check them out! If you can, drive to Autozone, they will scan your car free of charge.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-20-2006, 09:14 PM
I think Autozone only scans 96 and newer.
Old 01-21-2006, 07:56 PM
Stevo2's Avatar
Kinda depends on where you got the wires also. I replaced mine with the top of the line NAPA wires and they have been on for about 10 years. These replaced the factory wires that had bad boots. I also only use NAPA or the OEM wires, the ones from places like Autozone have been junk.
Take a look under you hood in the dark of night and see if you see any sparks flying around, you can also take a spray bottle and gently mist the wires to see if the engine acts up.
