Old 01-15-2006, 01:30 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
engine swap advice
whats up guys. some of you know that i will be putting a dohc zc into my crx very soon. like a week. i just wanted to get some advice on the swap. just any advice you wish you had before you did your swaps and stuff like that. thanks
Old 01-15-2006, 10:01 PM
arodg25's Avatar
arodg25 arodg25 is offline
Re: engine swap advice
what engine do you have in your car now?
Old 01-15-2006, 10:13 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Nice choice in motor. I am currently driving with same swap and love it!!. However some will disagree. Great/cheap swap. What tranny you using? If SI basicly everything works with ZC. My advice is to change as much as possible on engine before dropping in. Save you a lot of headaces later on.Wiring needed (If SI or already MPFI) is to Extend 2 wires from 7 pin connecter to Cam sensor.Also dont forget to Cover these ports on manifold or RPM will be bouncy
Also you must trim out hood. if not timing cover will rub and could cause belt to slip teeth
The upper radiator hose is from a 84 Honda Accord and though it fits good it is a little long. It just has to be trimmed down a bit.
PM7 Ecu best for ZC because it is OEM ECU for this motor.However could be hard to find. I have got PG7 and fine enough.pulls harder than pm6 thats for sure. If you plan on going with pg7 the case is different.Just use Pm6 case and works perfect.
might have forgot something
oh well .GL
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 01-16-2006, 03:36 PM
2poor2tune's Avatar
thanks. right now it has a b15b2 with a blown head gasket and wont pass emisions so im just gonna swap it and then run it threw. im not sure about the tranny i bought a civic with it already in it so im not sure. im guessing it came with the zc tho.
