Old 01-15-2006, 12:20 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Engine not warming up....Need opinions.
Got a 1994 Cavalier VL with the 2.2L 4 cyl.
The thing is in the summer the needle always reads between 1/4 and 1/2 and when it reaches half for example when idling, the fan will turn on which is normal.
Now in the winter here, the temperature needle will come up to just a hair above 1/4 and then drop below 1/4 as the thermostat opens. When driveing, the themperature will never get above 1/4 which is really taking a lot of time to warm up the interior.
Is this normal or do I have a partially open thermostat?
It should be running hotter than that.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-15-2006, 02:11 PM
unbe unbe is offline
Re: Engine not warming up....Need opinions.
I would try a new thermostat.
Old 01-15-2006, 03:47 PM
BlazerLT's Avatar
AF -Advisor
Yea, my thoughts too.
It should be between 1/4 and half when operating regardless of the season.
Anyone else with a 1994 or older to comment on this?
Old 01-20-2006, 11:53 PM
vamc's Avatar
vamc vamc is offline
The thurmastat sounds right. Is your radator under pressure, that also could be it. It shuld be under pressure.
Old 01-25-2006, 02:29 PM
ude_loose's Avatar
ude_loose ude_loose is offline
Send a message via Yahoo to ude_loose
so if when driving you are between 1/4 and 1/2 that is normal because my car alwasy use to go up all the way to 1/2 until i took it in to get the head gasket replaced because it was leaking antifreeze and my heater works even better now..
Old 01-25-2006, 04:38 PM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
thermy from napa works don't buy a cheap one
