Does the Plymouth voyager have a dianostic?
I used to have a dodge intreped 1994 it had a system on it where if you turned the key back it would flash you a code to get you in the right direction of what was going on with it. I was wondering if the 1993 voyager had a simular set up.
We had just put gas in our voyager and drove about 15-20 miles (highway). Then we pulled into a parking lot. The minute we hit the parking lot she died. Then I tried to start it and it sputterd then died. Then tried again and it would crank but would not turn over. I check the fuel bar and it had preasure in it. I then check the plug wire with a screw drive I had fire. Air filter is clean. So now I'm at a loss. Where do I go from here? What do you guys think? Thanks in advance Last edited by Chango; 01-15-2006 at 10:44 AM. |
Re: Does the Plymouth voyager have a dianostic?
Turn the key on and off three times. On the third time the Check engine light should flash. Counting the number of flashes will give you the code you are looking for. Your problem sounds like one of three things, bad crank position sensor, bad fuel pump or the engine jumped time. Good Luck and welcome to AF!
I thought it would give you a code on where the mil. is? My 2003 does that.
Thanks! I will give it a shot A.S.A.P!
Let us know how it turned out!
