Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-14-2006, 09:35 PM
83scottsdaleowner's Avatar
83scottsdaleowner 83scottsdaleowner is offline
Send a message via MSN to 83scottsdaleowner
92 Bonn... Gas? and Blinker
1992 Bonnevile SE
When my bonn gets to about 1/2 a tank and i take a sharp turn it seems like it wants to stall out, i have no idea whats goin on. Also where is the blinker relay located? Thanks
1992 Pontiac Bonneville:
Old 01-14-2006, 10:30 PM
Malachias Malachias is offline
Re: 92 Bonn... Gas? and Blinker
Apparently you have a broken plastic "pan" that goes inside the fuel tank where the fuel pumps works. With a half tank, in a turn, the pump canīt suck
the fuel. The blinker relay goes in the center of the fire wall in a big plastic box with a diagram in the back of the cover.
Keep in touch. Good luck.
Malachias (Brasil)
Old 01-15-2006, 07:46 PM
thanks, is it hard to fix or replace the "pan"?
Old 01-15-2006, 10:30 PM
I said "apparently. First of all you have to take out the tank, take out the fuel pump cover and look inside to make sure you have a broken pan. If yes you have two ways to look for. 1 - New tank (expensive at dealer and cheaper at junkyard. You canīt fix it.
2 - Keep ever your fuel level above the half tank, if not, avoid sharp U turns
and donīt feel guilt for to not fix your Bonny.
Did you fix the blinker relay?
Good luck.
Malachias (Brasil)
