Old 01-14-2006, 03:52 PM
samlewis samlewis is offline
Question engine swap
hi i'm new to forums. its seem the thing to try. i know cars. i need to know what car and years i can put a 1.9 ford escort motor in. i have one with 16000 miles in a total car. how do you folks find out such info.
Old 01-14-2006, 05:42 PM
Black2000Ranger Black2000Ranger is offline
Re: engine swap
What I know of, you can use the 1.9 from any Escort LX with a 1.9 liter from 1991-1996. You can get them from Escort wagons/sedans/hatchbacks, and if memory serves me right you can get them out of Mercury Tracer hatch/sedan/wagons as well, just as long as it has that 1.9L engine. Try www.car-part.com ,and search for your year car, it'll bring up everything that is interchangable. Welcome to the Forums.
-Scott
1996 Ford Escort LX
1.9L SEFI
Andy's Auto Sport Intimidator 2 Full Body Kit
Old 01-14-2006, 10:43 PM
RatLabGuy's Avatar
RatLabGuy RatLabGuy is offline
Send a message via AIM to RatLabGuy
Re: engine swap
Wait, I wonder if Scott missed your point. You mean you HAVE a 1.9L and are looking for what cars are good to pop it into? I guesst he point is the same though, yes the Merc Tracer is an Escort clone so everything matches.
But, you should know - the 1.9 isn't a wonderful motor, HP/Torque wise. 93 hp I think? Not an ideal power plant to toy around with.
Put it in a go-lart, lol.
Old 01-15-2006, 09:49 PM
josh_jonze josh_jonze is offline
Re: engine swap
I would go look for a 1991-1996 escort GT with a 1.8L DOHC. if you set them up right it's fast as shit. i have a 94 EGT and so far it has beat acura integras, older 5.0 mustangs, and just resently i have raced a 1989 I-ROCK comaro by 3 car lengths. the kid was shitting himself. it will smoke a honda any day. you just have to know WTF you are doing. so far i took my 1.8 to the machine shop had it all rebuilt. i got new pistons, crank, flywheel, clutch, head port and polished, cam gears, cams, springs, valves, pullys, the list goes on. I run low 13's high 12's. and remember weight reduction is a MUST! good luck!
Old 01-16-2006, 07:41 AM
Re: engine swap
thanks scott i'll try that web site. you folks should know i'm not trying to make a speed car. i just have a totaled escort with 16000 miles and need a donor body. thanks again.
Old 01-27-2006, 02:33 AM
UnexplodedCow UnexplodedCow is offline
Send a message via Yahoo to UnexplodedCow
Re: engine swap
The 1.9 will fit in any year of Escort/Lynx/Tracer. Even the 2.0 late model cars had the same engine mounts as far as I know. You'd be better off to look into an '81-'90 first gen, though, as theyr'e the easiest, and best. If you have any questions, let me know, and I'll answer them to my best. I've done some work on those years...a lot, actually. You can also fit the 1.9 in a tempo, as it uses the exact setup as an Escort for the engine, just make sure you get a manual, the 1.9's were slooooow with an auto. So go look for a '81 to '90 Escort, or '84 to '94 Tempo with a dead engine, and that'll be easiest.
Old 01-27-2006, 02:32 PM
Re: engine swap
thank you very much. i had no idea i could look for a tempo as well. i know tempos well i have own one since 84 but never had a motor go. so if i understand you right i could get a 93-94 tempo and put the 2002 1.9 motor and 5 speed trans in very easy. again thanks
Old 01-31-2006, 03:29 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Re: engine swap
What year is your 1.9 motor? Ford stopped making 1.9's in 96 and your saying it's a 2002? Do you have the 2002 2.0 SOHC or the 2.0 DOHC motor? Plus you need to be carfull with inbreading newer motor's with an older chassis, the older ford stuff requires a distributer, Escorts went to coil packs in 1991.
EDIT!
also, the Tempo shares the same engine bay as the 1st gen Escort only, starting in 91 Escorts went to a Mazda platform. So the tempo mounts wont be compatible with a motor newer then 91.
I make slow Escorts less-slow.
My cardomain
