Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-14-2006, 03:41 PM
phuonghoangtuan phuonghoangtuan is offline
Lincoln LS 2000 & Engine Light on
Hi all,
I've just bought LS 2000 but i have a problem with its check engine light, It is steady at below 60mph and it's blinking above 60 mph. Beside that it consumes 2.3 mpg, thats terrible!!!
Anyone has previously experienced with this please help me!
Thank you so much and have a nice day!
Old 01-14-2006, 04:44 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Lincoln LS 2000 & Engine Light on
Welcome to your first post here on AF.
If the check engine light is on you need to get a scanner on it and check for codes.
Post back code no.
A blinking light points to a missfire.
How many mile on tune up?
Check out the tune up end.
And you replace the plugs use the OEM motorcraft plugs the book calls for.
If you need the codes checked.
Auto zone and some other parts places give free code checks.
But beware on there free advise.
Use Caution when getting the free code checks please.
Some parts places do offer free code checks. And also free repair advice. But beware. Just get the code no and post it back here and someone will help you.
They offer the free code checks in the hope of increasing there parts sales.
Almost all of them will also offer mechanical advice and some know what they are doing.
But just remember most of them are parts people pulling codes for free.
Not trained professional tech/mechanics. Even if they pull a 02-sensor code or another sensor related code it does always mean to replace that sensor and your problem will be fixed.
Please just get the code no and post it back here and we will help you.
MT
MT
Old 01-14-2006, 11:38 PM
Hi,
Thanks so much for your advice. The mileage is currently 140000! I just bought it two days ago, where i could scan for the code check free please? I have already asked the dealer but they will charge me $102, thats too much
I will be back here if i have the checked code soon.
Thanks again for your help
Old 01-15-2006, 10:03 AM
MT-2500's Avatar
AF - Advisor
10-5 on the dealer scan. Little high for a scan or code read out.
If that includes a complete diagnostic check out might not be bad deal if you have a major problem and they do the stuff they are supposed to and have a factory trained tech do the work.
But some just get the greese monkey to read the codes in 5 minutes codes check.
Auto zone and some other discount parts places read the codes for free.
But read the caution from upper post.
Get codes no and post back codes.
A blinking light is a missfire.
A steady light means a code has been set.
MT
MT
Old 09-17-2007, 09:38 PM
DazeyD143 DazeyD143 is offline
I have a 2000 LS V6. I have already had the lincoln dealership replace the 5th coil (misfiring) and the fuel pump. We have been having problems with it again. Everytime it rains, somehow water gets in to the engine and it won't run right until it dries out (about 2 days). The car has no pick-up, and constantly misfires. The check engine light came on again, so we took it to Advance Auto Parts to have them read the codes and they said it was the 3rd and 6th coil misfiring. So, today we replaced all the spark plugs, and found that one of the old ones was covered in oil. The spark plugs were in horrible shape and NEEDED to be replaced. We thought this might fix it, but it is still running rough. I can't afford to take it back to Lincoln...someone please help!
Old 09-18-2007, 01:30 PM
Drag214 Drag214 is offline
Lightbulb Re: Lincoln LS 2000 & Engine Light on
I had similar problems with my LS. I posted every step of the ordeal on this site. Look for my thread. The title is " Salvage LS Need Help".
Old 09-18-2007, 10:31 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Was the spark plug or the coil covered in oil? Coil covered in oil would indicate the spark plug well seals. If it's the spark plug covered in oil, that would indicate something much more serious, such as low compression/bad rings. Also, if spark plug, are you sure it was oil and not raw fuel? A misfiring spark plug can look quite similar to an oil saturated spark plug.
Were the coils replaced with OEM or aftermarket coils? On certain cars, there have been issues with aftermarket coils (and plug wires) having the wrong height to the boot, preventing them from sealing against the valve cover tightly. Water could run down between the coil boot and valve cover and cause a misfire until the moisture evaporated away.
-Rod
Old 10-11-2007, 06:36 PM
lorr43 lorr43 is offline
I just bought a 2000 Lincoln LS two days ago and today a funny shaped light looks almost like a light bulb) came on. It's right next to the oil light. I do not have a manual. Can anyone tell me what this light means?
Old 10-11-2007, 07:13 PM
MT-2500's Avatar
AF - Advisor
Welcome to AF.
Owners manual may cover that.
Hit the New Thread button upper left corner and start a post on it.
MT
MT
Old 10-12-2007, 08:52 AM
MT-2500's Avatar
AF - Advisor
Some of the lights are maintenance reminder lights.
Check here for a service manual.
https://www.fleet.ford.com/maintenan...ls/default.asp
MT
Old 11-21-2007, 07:21 PM
Shorod- It was the spark plug covered in oil. We have replaced all 6 plugs and the one closest to the rear of the car on the left side is the one we are finding oil on. The new one also has oil on it. Check engine light has been on...We have read the codes and they said slow response sensor 1/1 and misfires on cylinders 3 and 4. We replaced the oxygen sensor and that didn't fix the prob, so our next step is to replace coils 3 and 4 but we are not sure which ones they are. Have any clue where I might find a diagram of which coil is which for my 3.0 V6?? Also, should we go ahead and change all 6 coils or is that not necessary? Thanks for your help!!
Old 11-22-2007, 09:51 AM
shorod's Avatar
SHO No Mo
Is it the ceramic portion of the spark plug that is covered in oil or the electrode (spark) end that is covered? If it is the electrode end, that would indicated a problem with piston rings, valve seals, etc. If it's the ceramic end that the coil plugs in to, then replacing the plugs and coil without fixing the spark plug well seals will not fix anything long-term.
The slow response of the oxygen sensor could be partially due to the misfire. I'd start by fixing the misfire, then see if the slow response code comes back. If it does, the constant misfires could have damaged the sensor to where you'll need to replace it too, but I wouldn't start there yet.
On your V-6, cylinder #1 will be the cylinder closest to you on your left as you are standing in front of your car with the hood up, looking at the engine. Cylinder #2 will be the middle cylinder on the left, and cylinder #3 will be the cylinder nearest the firewall on the left. Cylinder #4 will be the cylinder closest to you on the right.
The coils on cylinders 1 through 3 are not real easy to get to. You don't want to have to take the intake off too many times, so assuming the oil is due to leaky spark plug well seals, replace the valve cover gasket sets (which should include the plug well seals) and you may want to replace all three coils on the left side as well.
-Rod
Old 10-18-2008, 04:19 PM
blueboy76 blueboy76 is offline
I too just had the check engine light come on my Lincoln LS 2000, I took it to AutoZone for a free reading and they gave me code 152. I was told it was an oxygen sensor (#2) but they recommend to have them both replaced, cost is $168.00, can someone please verify this?
Originally Posted by phuonghoangtuan
Hi all,
Old 10-18-2008, 05:16 PM
MT-2500's Avatar
AF - Advisor
Welcome to AF.
168.00$ is a high priced free code check!!!!!!!!
Somebody has there wires crossed on that code deal.
You need to be looking at bank 2 sensor 1 not sensor 2.
And remember a code does niot say replace the sensor.
You need to check it out.
This post is old and dead.
Let the dead rest in piece,
Always check the date on the post before answering to it.
And to save on hyjackng a old dead post.
Please start a new thread/post if you need help on your car.
Good Luck
MT
Old 10-18-2008, 09:12 PM
shorod's Avatar
SHO No Mo
Welcome to the forum!
Like MT-2500 suggested, the code P0152 does not suggest that the O2 sensor is the problem, but rather that there is a wiring issue for the sensor. And, again like MT-2500 mentioned, this code is for bank 2, sensor 1. Per the factory service manual, "The HO2S Sensor Signals are monitored for an over voltage fault. The code is set when HO2S signal voltage is 1.5 volts or greater."
Also per the service manual, likely causes are:
  • HO2S Signal Circuit shorted to Heater Power inside of HO2S sensor.
  • HO2S Signal Circuit shorted to VPWR or VREF in harness.
  • PCM failure.
-Rod
