Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-14-2006, 03:23 PM
speedncivic speedncivic is offline
engine build
I am getting ready to build a B18c1 for turbo. I originally planned to bore the block to 84mm and sleeve it, run low compression pistons and rods. However, recently, I was told to bore it out to 2.0L and build it like I were building a B20 for turbo. Does anyone know the advantages and/or disadvantages of both builds?
Old 01-16-2006, 09:53 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: engine build
if you plan on sleeving both blocks. advantage vs diaadvantage......................the b20 build is more costly.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-16-2006, 12:23 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
Re: engine build
An 84 MM bore would be boring out to a 2.0L B20. I believe right now you are at 81mm.
Thats how they make a B18B into a B20 is by boring it from 81 to 84.
So since you are using a B18c Which has slighly less displacement than a b18B It will still be slightly smaller than a B20 when bored out to 84. However its not a significant difference.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 01-16-2006, 05:39 PM
londa hover londa hover is offline
Re: engine build
i plan on sleeving my block, I wanna go with an 84mm bore, if I bored mine to 84mm, I know the oem head gasket will have to be bored out too. But, am I going to have to match port the head? Or can I just leave it? People said all it really does is lower the compresson ratio. Do they make gsr pistons to an 84mm bore or just buy B20 pistons? then would the compression be the same if I bought Supertech 9.6;1 pistons? What all will i really need to go if I bored it out to 84 mm
civic eg dx hb
d15b7
hondata es200
small 16g with 10psi
198whp@6850
168tq@5100
13.6@101 w/21" slicks
^^^^SIGNATURE FROM 2004
current setup
b18c
gt42r
9.61@158
Old 01-16-2006, 10:01 PM
TurboGSR96's Avatar
TurboGSR96 TurboGSR96 is offline
Send a message via AIM to TurboGSR96
Re: engine build
i dont think this is possible....i could be wrong....in order to bore a sleeved B18 out to 84mm....you would first either have the machine shop overbore 3mm what they would of previously done or bore the sleeves out once they are installed an extra 3mm, but wouldnt that kinda take away the advantages of an aftermarket sleeve by once again making the walls thinner? please respond if you are on the same page as me on this.
R.I.P 00' ITR #479
1996 GSR: Built Bottom - Built Head - Big Injectors - Big Turbo - Computer Thingy - 500+ whp
*2-6-06* Waiting for the Full-Race Stg 3 with GT35R
.82 a/r Upgrade and Nitrous Express NXL
http://www.cardomain.com/ride/2241056
Old 01-18-2006, 07:20 PM
gmcuajo gmcuajo is offline
Re: engine build
I don't know too much about that, but if you want sleeve the block and bore to 84mm you have to bore the block to some 86-87mm to make room for the sleeves. This will make the cylinder wall thinner. Search on the web and other forums...
