Bird Bath
Still have a couple things to iron out. Gonna let a friend drive it that knows the F-Body better than I to determine if it is running correctly. Feels like it has NO power until around 2400 RPM's...which may just be the cam. Even then...just doesn't feel like it hits that hard. Maybe it picks up around 3500+
Gauges need installed. Going to hit that up Monday. New BFG's need mounted along with an alignment. Sometime next week. Anyways.... Much better....but the paint did suffer a little from the swap. Like a cheapass I didn't pick up quarter panel skirts.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
Re: Bird Bath
ooh la la! good job on everything! congratulations on having one fine looking T/A. and good luck on finding out why it seems like theres no power under 2400rpms.
1996 v6 Pontiac Firebird
Re: Bird Bath
Must be nice.... The day you washed your car it was -4 here in the afternoon with heavy winds, tonight its 39 and dropping, heavy winds. Thats why I put the summer toys away in early november and take them out in mid april...
Rusting out Honda Civic $900 Fart cannon muffler: $300 Assorted stickers advertising products you'll never own: $50 Having your @ss handed to you by a brick shaped suv: Priceless. Yup, I own the suv. |
Re: Bird Bath
what's the current status Luos?
Re: Bird Bath
WOW! That is a sweet looking car. LS1's in general don't make good power under 3000 rpm's. What size cam did you go with?
1999 Pontiac Firebird Formula 100% bone stock. No really it is
Re: Bird Bath
Current status.....snowing.
![]() Shooting fire out the exhaust....and the best I can tell, it is tune related. Got to ask some questions to a couple friends and see what I need to change. Darren...248/254 629/622 113
Re: Bird Bath
fire out of exhaust, hell ya fast and furious, lol
95 Z71 Silverado 4x4 ext. cab Mods- Flowmaster Exhaust,Intake |
Re: Bird Bath
Good luck with that. Hopefully you'll get some great track numbers from her.
Re: Bird Bath
That is sorta the problem.
It needs a dyno tune...but I am going to break it in first. Well...the place that will be dyno tuning it did a base performance tune for me...although it doesn't appear he did enough. I will get ahold of him Monday and see if he can help.
Re: Bird Bath
lookin niceeee
Re: Bird Bath
Don't you have a 402 in there? Did you drill out a small hole in your TB blade? Ok..as far as the no power below 3k..it could be your cam, but if its the tune, sounds like you might be loading up hard core on fuel. He needs to dial in your LTFTs(Long Term Fuel Trims) and adjust your primary and secondary VE Table(Volumetric Efficency(sp?)). Once he has this taken care of then he can start your power tune. He might have turned down your timing hard core too..who knows w/o seeing it but I doubt it. If yo'ure shooting flames out the back, I would think that's a very rich condition...but don't quote me. I can't wait until you get that thing running. Its going to kick ass. Extreme is getting started on my car. Can't wait...that and I'm moving to FL so I can drive my car year around WOOT!
DarkblueTA GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit 2007 Nissan Titan Daily Driver. 2* advance
Re: Bird Bath
where in fl are you moving to? and luos, nice, im liking it.
87 firebird formula ws6 (currently has a old 78 305 with the following upgrades, including lots of miles and stock heads and internals....oops) crane cam cam specs performance valve springs and retainers, flowtech headers, 255 lph fuel pump, holley 600cfm carb, weiand single plane manifold, a healty diet. 14.90 1/4 mile....just wait for the 406 to be finished MY VIDEOS MY PICTURES -Tom |
Re: Bird Bath
It is VERY rich. Rich enough to foul plugs QUICKLY!
I have HPTuners...but I have no idea what to change to lean it out enough. 3,000!!!!
Re: Bird Bath
Palm City
Re: Bird Bath
Your Injector Flow Rate table. its in engine/fuel tab. what injectors do you have in there. not sure which update you have, but the newer IFRT has the numbers in each cell as xx.xx (42.00) which is your injectors vs the the old table which was x.xx(1.87). Make your IFRT the same all the way across for now(if you have 42# injectors, put 42.00 in there). Then use your scan tool and drive around using different Throttle Position angles to get as many cells filled in the LTFT(Long Term Fuel Trims) histo-gram on the scantool and if the #s are positive...(I don't remember this part...but if it gets higher positive numbers..just do the opposite). Just add to those cells. Otherwise subtract. Make all your LTFT between 0 thru -7. once you have that taken care of, you have your injectors dial'd in. If you have questions, you know my AIM name...hit me up on there. Matt
