Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 01-14-2006, 01:14 PM
patarusky patarusky is offline
Unhappy Codes P0121 and P0203
Driving down the freeway I suddenly lost power & check engine light came on. Autozone code checker showed these codes: P0121,P0203,P0204, P0208. I think the first one is the throttle position sensor. The other ones appear to be fuel injectors for the misfiring cylinders. Would the TPS going out affect the injectors like that? Can I drive it this way until I can get parts? It runs but has little power. Oil and temp are all fine. Thanks
Old 01-14-2006, 01:40 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Codes P0121 and P0203
Replacing your TPS should fix the fuel injection malfuntion. Replace it first, have the computer reset and see how it goes from there. The TPS controls the fuel flow, so that would explain your other codes setting in.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-16-2006, 02:21 PM
x3mtm's Avatar
x3mtm x3mtm is offline
Send a message via AIM to x3mtm
Hey, I Dont Know If This Helps, But When I Had The Tps Go Bad On Mine, The Engine Light Came On Couple Of Times And I Lost Some Power, More Noticeable While In The Highway. Once I Changed It, It Was All Set.
Old 01-21-2006, 02:48 AM
Cool Re: Codes P0121 and P0203
Just wanted everyone to know: I replaced the TPS sensor and reset the check engine light. All is well. The TPS will tell the injectors to misfire if it's bad and it was. $35 at the Zone. Patarusky
