Old 01-14-2006, 11:45 AM
|WYG|SS |WYG|SS is offline
Exclamation loose BOLTS!!!!!
Me and my dad were looking unjder the hood of my 91 sunbird 2.2L and cleand the terminals on the baterry and befor putong carb. back on i thought about checking the bolts on the crank case cause it looked like new oil was dripping out of engine and guess what, they were all loose so i had tightened them so that they wont keep coming loos i have to get torch specifications later. Could this cause the oil light and check engine light to come on? would this cause the engine to go into a low idle, and would it cause the engine to blow air out the breather tube on engine? could this cause any major problems?
any advice would d be appreciated.
Thanks, SS
Old 01-15-2006, 07:12 AM
Re: loose BOLTS!!!!!
i got the bolts- tightened to the right torch(excuse my spelling) the car runs alot better now. still can someone olz answer my questions.
Old 01-15-2006, 02:03 PM
unbe unbe is offline
Air out the breather tube can be a sign off excessive blowby of your rings causing too much crankcase pressure.Making sure you PCV is up to snuff might help but it can only do so much.Good luck
Unbe
Old 01-16-2006, 06:49 AM
i have been told about the blow by before. at eeast i got the problem fixed. im hoping on getting a job and might decide to over haul or try and get a used engine or a new one for 1500 cause the body is still good so i want to keep it.
