Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-14-2006, 11:41 AM
fischfly2 fischfly2 is offline
98 power door locks inop
98 bonneville power door locks don't work. I purchased a powere door lock relay but I don't know where it goes or if this will fix it. When I try to lock the door from the drivers door I hear a relay clicking under the glove compartment but I can't locate it. When I try to unlock the door the chime goes off. The same chime that goes off when I leave the key in ignition. Any ideas out there?
Old 01-20-2006, 11:47 AM
darrell328 darrell328 is offline
Send a message via MSN to darrell328 Send a message via Yahoo to darrell328
Re: 98 power door locks inop
the relay is located under the glove box. you have to remove the kick panel and it is located all the way to the right.
Old 01-22-2006, 07:58 AM
markwb's Avatar
markwb markwb is offline
Check the power door locks supply fuse also (not sure of location). It sounds like power is down to all four doors in regards to door lock function. The control part of the door locks seems to be working.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 01-22-2006, 04:53 PM
the fuse was blown under the glovebox kickpanel. Thanks for your help
