Go Back   Automotive Forums Car Chat > Ford > Contour
Old 01-14-2006, 11:00 AM
ty976 ty976 is offline
Unhappy Heater fan blowing fuses 96 Contour
I have been dealing with a wierd problem with my Heater/AC fan.
When the fan is on and running it blows the fuse when the selector is put in the floor or defrost position no matter what speed the fan is on.
I replaced the resistor pack and plug even though there was no evidence of burning.
The fan works fine when blowing from the front vents.
Please email direct if you can
Thanks
Any help appreciated
Old 01-14-2006, 11:37 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
have you taken it in for the recall pertaining to the fan blower?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 01-14-2006, 01:35 PM
Re: Heater fan blowing fuses 96 Contour
No I haven't taken it to the dealer. Just got it back from my son. Now trying to repair everything he neglected. I will take it as a last resort.
Old 01-15-2006, 06:31 PM
seasonalskier2006's Avatar
seasonalskier2006 seasonalskier2006 is offline
Send a message via AIM to seasonalskier2006
you might want to check the specs to see if the right fuse is in, if it is i might suggest raising the fuse raiting and be done with it but it is up to you.
Old 01-15-2006, 07:45 PM
Thats the worst advice anyone could ever give!!! Dont ever ever EVER raise the amp rating on a fuse! Thats a good way to just have a total meltdown for that particular part or even worse, an engine fire. They have specific amp ratings for a reason.
Btw, I would take it into the dealer as a first resort. Recall fixes are absolutely free.
"The CEG Nazi"
www.contour.org
Old 01-16-2006, 07:35 AM
Smile Re: Heater fan blowing fuses 96 Contour
Thanks guys but I found the problem. After thinking about it for a while I realized that when the selector is put into the defrost you are sending power to the compressor which I beleive is shorted since it locked-up over the summer. I disconnected the compressor and wha..la, no more blown fuses.
Thanks again
Tony
