Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 01-14-2006, 02:29 AM
nkukard nkukard is offline
Question Engine Coolent vs. Water
Hi Guys,
I'm sorta a n00b with performance, mods ... etc. However I'm getting there. I added a freeflow + branch to my Tib and also had a unichip added and dyna tuned. Brought me up from 185nm/106Kw to 202nm/119kw and gave it a more sporty sound ;-)
I have question though, I see in the manual it says you MUST NOT put more than 60% rich coolant into the engine. No where can I find how much the radiator takes, so I cannot work out how much to add.
Would putting pure coolent into the engine cause any damage? (glycol based coolant).
As far as I understand rust/scale forms with water, especially the highly processed water we have. If there is only coolant, no rust, no scale?
Regards
Nigel
Old 01-17-2006, 02:11 PM
peachferrari peachferrari is offline
Re: Engine Coolent vs. Water
I would not recommend putting in a higher concentration than what the manual recommends. It might cause your engine to run cooler than it's supposed to. If you can't find the capacity, just use a small measuring cup and mix the water and coolant 50/50 before you pour it into the radiator. For example, I have one that's about 1 liter, so I fill it halfway with coolant, then the other half with water and use that to fill the radiator and overflow. Or, you can usually find coolant that's already mixed 50/50.
Old 01-17-2006, 02:13 PM
Old 01-20-2006, 05:50 AM
Rickna's Avatar
Rickna Rickna is offline
IS-F
Just drain the coolant & premix it. That way you're sure.
Old 01-20-2006, 08:17 AM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
The thermostat is what determines how hot or cold the engine will run, not the coolant/water mixture. All coolant is used for is to keep it from freezing, or boiling over, and also lubricates the water pump.
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
Old 01-22-2006, 07:44 AM
BigTDawg BigTDawg is offline
Send a message via AIM to BigTDawg
the 2.0 takes about 7 liters and the 2.7 takes about 8 liters and i personaly woundn't buy the premixed stuff for the reason of you are paying them for water and you get less antifreeze and its like the same price rip off
