Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 01-14-2006, 01:18 AM
jamesmetairie jamesmetairie is offline
97 t-bird burned=
my son,s 97 t-bird,v/8 ran hot. by the time he could safely pull over the temp needle was maxed out.mechanic says maybe cracked head or blown head gasket. car has 160,000 miles on it. already it needed heater core and ball joint work . it is nice with leather,alloys,etc. what do you guys recommend in this case? thanks.
Old 01-14-2006, 08:10 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: 97 t-bird burned=
Hello
I'm not familiar with the engine in the t-bird. Does it have the 3.8?
Regards
Dan
Old 01-15-2006, 06:40 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Originally Posted by LeSabre97mint
Hello
Regards
Dan
The V8's were the OHC 4.6 liter.
The cooling system and combustion chambers can be pressure tested to accuratly determine the possibility of leaks, wear and damage. Before making a decision, it may be helpful to properly evaluate the engine's condition.
These engines are relatively expensive to rebuild. If you did rebuild it, you bviously still have the high mileage driveline to worry about, as well as the other repairs.
I suspect the repairs would exceed the value of the car, if it needs a new engine.
If you can find a decent used engine for not much money, a repair may be financially reasonable, especially if the body/chassis/paint is rust free and pristine.
Otherwise, just sell it for what you can and move on .
