Old 01-13-2006, 10:16 PM
chevyman4life88 chevyman4life88 is offline
need help w/ 4wd please read
hey guys i posted this once before but i didnt get any feed back i would really appreciate it if anyone could point me in the right direction any comments would be helpfull thanks...
Ok so I own a 88 chevy k1500 and the 4wd dosent work properly. i have been having a hard time diagnosing the problem so i am hoping some1 will be able to help me out.
When shift lever is in the 4wd position, in either 4 hi or low, it doesen't always engage, or when shift lever is in 2wd the 4wd will engage and the front drive shaft will spin without being locked into 4wd
I have tested the actuator in the front differential, replaced the switch on the T-case and checked for power at the connections. I dont know were to go with it next any ideas on what it could be?
Old 01-17-2006, 03:49 PM
g_rod66 g_rod66 is offline
Re: need help w/ 4wd please read
there is a vacum deal under the battery that when you pull the lever in to 4 that moves the pin that locks and unlocks the front diff. if it is unhooked the 4 wd will not work
1994 silverado z71 stepside
1999 cav z24
1991 honda crx si (for sale)
Old 01-17-2006, 04:20 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Now are you saying that the actuator in the front diff. will enguage by itself, or it stays enguaged after shifting out of 4wd.
Old 01-17-2006, 06:23 PM
fatmacsumo fatmacsumo is offline
Send a message via Yahoo to fatmacsumo
the first thing to do is ajust shifter into 2 wheel drive have someone hold it in place while you ajust it from the bottom next question does it have locking hub or automatic. is the actuator cable or power let me know
Old 01-23-2006, 05:23 PM
yea the actuator enguages its self when i am in 2wd but it dosent always do it its really random
Old 01-23-2006, 05:27 PM
i was told that it could be a short and im sure that is possible too, but i always thought that if it had a short it wouldnt get power?
Old 01-23-2006, 05:32 PM
horse482's Avatar
AF -Advisor
How many pins does the 4wd acuator have? If it is a two pin that I would upgrade to the 3 pin (Dealer only), or get a cable pull acuator. Yes it could be a short, check the connector at the t-case to see if it is melted together, that it what tells the truck to lock in the front diff.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 01-23-2006, 05:42 PM
Crasen Crasen is offline
A lot of people use the word short to describe any electrical malfunction because they just do not know any better. The term short is used to describe an undesired path to ground in an electrical system. What you are thinking of is an open, an open in a circuit will keep you from getting any power to actuator. If you want to troubleshoot this problem see if the electrical connector is getting any voltage when it is malfunctioning. Another thing you could do is disconnect the elsctrical connector when it is supposed to be in 2wd and the front axle is locking up, if the front axle is locked with the electrical connector unplugged it is the actuator, if it is not you are looking at the switch
Old 01-23-2006, 05:48 PM
cable pull actuator huh? that could work for me how much do they go for? is it east to hook up? i think that would solve my problem for good
Old 01-24-2006, 05:33 AM
your actuator is only supposed to have voltage in 4wheel high & 4 wheel low
only. sounds like adjustment problems or get a hold of a wiring diagram somewhere . some shops with mitchell on demand will print you a copy for a
small fee. they also can print you out a copy for dianoises & repair on 4x4s.
Old 01-24-2006, 09:23 AM
horse482's Avatar
AF -Advisor
I found the cable actuator on www.4wheelparts.com I think that they are about $150. Have not got one my self yet, but am going to. Tired of the acuator enguaging slow. Read the instructions, it looks very simple to install.
NO 4 N JUNK
