Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 01-13-2006, 11:14 PM
sibrian sibrian is offline
Send a message via MSN to sibrian Send a message via Yahoo to sibrian
Unhappy High Oil Consumption!
Hi, I'm Moises again, my 5sfe engine is using too much oil, I've runned only 1800 miles since last oil change, and I checked it today, and I was running at low oil I feel the engine is burning the oil. What should I do to fix it?
Old 01-14-2006, 02:43 AM
KimMG KimMG is offline
AF - Advisor
Re: High Oil Consumption!
Do a compression test on the motor. See if the rings are bad. Does your vehicle have a PCV valve? It may be bad.
Old 01-14-2006, 11:03 AM
calicelica calicelica is offline
holy peter, it doesn't end does it? :P what viscosity ratings are you using, and what brand? did you check the spark cables and rotor btw? and still gotta replace a plug from what I remember...
Old 01-14-2006, 01:41 PM
bigirb2002 bigirb2002 is offline
Send a message via AIM to bigirb2002 Send a message via MSN to bigirb2002 Send a message via Yahoo to bigirb2002
stop hot rodding it
Old 01-14-2006, 03:04 PM
I'm using Valvoline Max life (the red one) 10-30. My car have 189,000 miles. I"m going to change the spark plug and wires next week. My vehicle doesn't have a PCV valve, It has a EGR valve.
Old 01-15-2006, 03:08 PM
abrittis abrittis is offline
Unfortunatly, 1800 miles for a quart of oil on a car (yes, even a celica) with 189k miles on it - isn't unreasonable.
Most likely rings are starting to wear, and/or valve stem gaskets are leaking. Compression test should tell you how the rings are doing. A "puff" of blue smoke when you start the car in the morning is a good indication that the valve stem seals are leaking a little.
I just rebuilt my 85 22RE engine with 250K miles on it. I was burning a quart of oil abut every 900 miles.
Anthony
Old 01-16-2006, 02:18 PM
It doesn't burn 1 quart at 1800 miles, the car burns almost all the oil at 1800 miles after the oil change!
