Old 01-13-2006, 08:46 PM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
96 Cav, Starting Problem.
it starting to get worse as time goes on (it took 5 mins of trying before it started), but every morning (it only happens in the morning, after the first start of the day it will start up in a second) when i go to start my car, it takes a long time to start, the starter trys to start the car but it just wont start, starter sounds strong i can hear it, im guessing its a spark issue, just thought i would post and get some feedback, maybe other suggestions on what maybe the cause
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 01-13-2006, 10:12 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: 96 Cav, Starting Problem.
could be spark or fuel issue. But start with the cheapest things and work your way down the list.
Sea foam in gas tank ( aka injector cleaner)
Plugs gapped at .040-.045mm
Wires
fuel filter
Coil Packs if you have 2.2 non-eco
etc....
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-13-2006, 10:21 PM
roof roof is offline
Re: Re: 96 Cav, Starting Problem.
Im having a similar problem with the same car, Except when i pulled the plugs to investigate for spark, they were all dry no fuel getting in there. This has happend twice to me wiht the same results as above except flooring the gas seems to eventualy bring it to life, could it be dirty fuel injectors or bad fuel filter perhaps?
Old 01-13-2006, 11:26 PM
Wires
fuel filter
etc....
plugs gapped at .040-.045mm? < i donno, explain...
~Viper
Old 01-13-2006, 11:27 PM
Petekazel Petekazel is offline
Turn key in on (not start) position and off several times before starting and see what happens. If you kave no problem starting the car you have a fuel problem. I would start out by changing the fuel filter
Old 01-14-2006, 08:03 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Re: Re: 96 Cav, Starting Problem.
what he means is, the gap is the distance between point A and point B (see picture) you can buy a little tool to measure that distance for around $1-2 at any auto parts store
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 01-15-2006, 09:13 AM
ook, thanks.
~Viper
Old 01-15-2006, 02:49 PM
Lifted GMT-360!
If the gapping on the plugs isn't correct it can lead to missfiring or back fires. I've been there, done that. The tech at the delership said they were suppose to be at .030-.035..... defintely not! This is another reason why i don't go to them anymore. Note: that gapping is for Stock AC delco plugs. That gapping will need to be changed if you add Boost to you car.
