Old 01-13-2006, 08:08 PM
SoupMotorsport SoupMotorsport is offline
Send a message via AIM to SoupMotorsport Send a message via MSN to SoupMotorsport
Help with flat bacl paint!!!!!!!!!!
Well im going to paint my wrx Rally in flat back, i have tamiya spray and just wondering if i can use the same process as regular painting. ANd do i need primer for this as well? THanks
Old 01-13-2006, 08:09 PM
freakray freakray is offline
AF Modelrater
Re: Help with flat bacl paint!!!!!!!!!!
Yes to all of the above.
AF User Guidelines
Old 01-13-2006, 10:10 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Yup, paint like normal.... and then get pissed at the 'armor' modelers when the flat paints come out so smooth and even when the glossies take so much practice to get right. LOL
Old 01-13-2006, 10:53 PM
LOL ok man thanks alot, but still wondering if i need primer .
Old 01-13-2006, 10:57 PM
Jaymes's Avatar
Jaymes Jaymes is offline
or you can be lazy and lay down some black primer and be done with it
Old 01-13-2006, 11:27 PM
well will teh tamiya just do?
Old 01-13-2006, 11:40 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
I would use primer.... but if you wash the body real good in soapy water and do some light mist coats first of the Flat Black then maybe it will turn out OK.
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 01-14-2006, 12:49 AM
digitalbanzai's Avatar
digitalbanzai digitalbanzai is offline
Heck, I don't see much of a difference between black primer and flat black.
Old 01-14-2006, 02:06 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Re: Re: Help with flat bacl paint!!!!!!!!!!
I used sometime painting underpanels: the only problem will be in highlight, so spray in light coats an you'll skip primer (in other word prime with the same MB)
gio
Old 01-14-2006, 03:44 AM
I've used flat gray as primer numerous times and don't get a lot of trouble
Old 01-14-2006, 05:05 AM
klutz_100's Avatar
TBH, why would you even consider NOT using primer?
Primer isn't that expensive and goes a long way, it dries quickly, highlights surface problem areas so you can fix them before it's too late, goes on very smoothly in my experience (in fact, it's always my best paint job! ), and most importantly it gives your paint a good surface to fix into so if you intend masking later for detail painting there is virtually no chance that the masking tape will pull off the paint from the bare plastic (been there, seen that, got the T-shirt ).
Put all that against the cost of not using a primer and then being totally pissed off, dissapointed and having to do it over or accept second best.
I prime EVERYTHING without exception. I just don't see the point of cutting corners right from the start of a build/paint job - there are so many places later where I will have problems anyway.
Old 01-14-2006, 05:15 AM
gionc's Avatar
Authorized Vendor
Steve, you become to be my kit's philosopher: I follow You
(for 1 only time I'm not jocking)
cheers
gio
Old 01-14-2006, 05:37 AM
klutz_100's Avatar
Re: Re: Re: Help with flat bacl paint!!!!!!!!!!
Maybe my new avatar?
Old 01-14-2006, 05:42 AM
gionc's Avatar
Authorized Vendor
Re: Re: Re: Re: Help with flat bacl paint!!!!!!!!!!
ABSOLUTELY
gio
Old 01-14-2006, 06:11 AM
Gamerxz's Avatar
Gamerxz Gamerxz is offline
Primer b4 Paint... 100% support to that.. it makes the paint settle much much much much much much better! finish is nicer as well...
Cheers
