Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 01-13-2006, 07:34 PM
L8R_H8R L8R_H8R is offline
Est. HP gains from a 70mm Throttle body?
I have a 96 prelude and i was wondering what kinda hp gains i could expect from a 70mm throttle body?
At the time, McLaren was racing successfully with Honda engines, and it seemed logical to approach Honda for an engine meeting Murray's requirements. But the Japanese declined, feeling that they could not spare the capacity to develop such a project.
Old 01-14-2006, 12:04 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Est. HP gains from a 70mm Throttle body?
Expect to loose power if you don't have higher compression/wilder cams or FI.
Old 01-14-2006, 12:14 AM
well, say i were to have all that
Old 01-14-2006, 01:23 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
then you'd gain more power, but by the sounds of it, you don't have any of the above....you'll gain top end, but sacrifice mid range....your best bet is a new IM, header, or cams.....TB just isn't going to help a lot.....especially since the stock mani only accomodates a 60mm or somthing like that
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-31-2006, 11:13 PM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
i put a bbk 70mm on my friends si. the car just had itr cams, intake, header, exhaust, and it made the car a lot slower.
Old 02-01-2006, 12:50 AM
banditkiller banditkiller is offline
Send a message via AIM to banditkiller
Going with to big a tb on a non f/i car that isnt built will cause a loss in power simply do to the fact that you lose intake velocity. Think of a garden hose, a 1 inch garden hose at say 50 psi will cause more pressure and therefor a faster rate of flow. No compare that same 50 psi on a fire hose. Because of the loss of pressure there is a loss in velocity, causing the water to merely trickle out. Thats the best way I can think to describe it.
R.I.P Hypsi87
My mom always told me that fastest way to someone's heart is through their chest. Watch out for ppl with pointed objects.
Old 02-01-2006, 08:08 AM
TurboGSR96's Avatar
TurboGSR96 TurboGSR96 is offline
Send a message via AIM to TurboGSR96
because the car didnt have any porting work done too
R.I.P 00' ITR #479
1996 GSR: Built Bottom - Built Head - Big Injectors - Big Turbo - Computer Thingy - 500+ whp
*2-6-06* Waiting for the Full-Race Stg 3 with GT35R
.82 a/r Upgrade and Nitrous Express NXL
http://www.cardomain.com/ride/2241056
Old 02-05-2006, 10:52 PM
GoRi GoRi is offline
Question Re: Est. HP gains from a 70mm Throttle body?
so what if the tb was smaller in diameter would dat help gain anything?
Old 02-06-2006, 12:11 AM
CivicSpoon's Avatar
There is no Spoon
No. Honda put those size throttle bodies on it for a reason. Take the B-series for example. If a smaller throttle body would have made more power, they would have used the same t-bodies as the D-series.
Old 02-06-2006, 04:49 PM
TurboGSR96's Avatar
Funny......Cant say im suprised but funny none the less.
R.I.P 00' ITR #479
Old 02-06-2006, 04:50 PM
TurboGSR96's Avatar
What about an intake manifold......cant stuff 70mm worth of air through a 60mm hole, somethings gotta give...
R.I.P 00' ITR #479
Old 02-06-2006, 10:46 PM
hxgaser hxgaser is offline
Amount of fuel/air mixture that can get into a combustion chamber for a naturally aspirated motor has a limit. Think of a syringe... If you pull the syringe piston, amount of liquid coming up the syringe cylinder is always the same. So even if one has a larger throttle body, the actual volume of air and fuel mixture that can get into the cylinder is still the same. In addition, by having a larger TB, the mixture is now lean. Too much oxygen... Of course the engine management trys to enrich the mixture due to leaning detected by the oxygen sensor and dumps more fuel in. This increase the total mixture volumn that is running through the intake, but that total volumne can't get into the cylinders. So a flooding condition is essentially created. Hence the reduced performance.
Of course if you compress the charge air via forced induction, then you can cram more of the mixture into the cylinder.
