Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 01-13-2006, 07:22 PM
pdfbjf pdfbjf is offline
2000 Silhouette ABS Idiot Light
Hi There! The ABS Warning light is on. Will having a normal brake repair (pads and rotors turned) make it go off, or is this indicative of something else?
Also, every once in a while the oil warning light comes on accompanied by a chime. Oil is full, no change in how the engine is running or increased heat, just the chime. Maybe just a sensor or something (I hope, I hope)?
Thanks
Old 01-14-2006, 11:52 AM
cdru's Avatar
cdru cdru is offline
Re: 2000 Silhouette ABS Idiot Light
The ABS light won't be fixed by a break job. There was a malfunction somewhere in the electrical sensor circuits. The usual cause of this is a wheel speed sensor located as part of the hub/bering assembly.
The oil light could be a malfunctioning sensor or possibly low oil pressure (failed oil pump, leak, etc).
Both problems should be looked at soon.
Vinyl adds horsepower, right?
