Old 01-13-2006, 05:50 PM
bag91's Avatar
bag91 bag91 is offline
Speedo off affecting smog?
Will the speedo being off affect a smog test?
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 01-13-2006, 05:57 PM
BLAZINGZ28 BLAZINGZ28 is offline
Re: Speedo off affecting smog?
Well it might because they take it up to certain speed and then they take there measurements and it it's off big time then it could throw it off, that's atleast what i think.
1995 PONTIAC TRANS AM LT1 6SPEED.
Old 01-13-2006, 06:08 PM
bag91's Avatar
Where do you flippin fix it, can I buy reprogrammer or something?
If so how much?
K/N filter
3.73's
B&M Megashifter
180 thermostat
3" exhaust cutout
Old 01-13-2006, 06:31 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Re: Speedo off affecting smog?
If so how much?
ya, i am going to get 3.73's also byt befor i do i want to know how the fix it, anyone know?
Old 01-13-2006, 06:44 PM
I'm more than positive you need a custom tune because there isn't a hypertech programmer for the lo3.
Old 01-13-2006, 06:45 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
i coulda swore I told you you had to replace the speedo gears in the tranny tailshaft already.
Old 01-13-2006, 06:47 PM
Genopsyde's Avatar
The President
From TGO...
Q: How to I calibrate my speedometer for new rear-end gears?
A: Determining the precise speedometer drive gear/driven gear combination required for a rear axle ratio change is surprisingly easy-if you know the existing combination and axle ratio. Whip out your calculator and follow along. Let's assume that your F-Body is currently equipped with 2.73 gears and that you're planning to install a 3.73 ring and pinion. If you didn't change speedometer gears, actual vehicle speed would 73.1 percent of indicated speed (2.73/3.73 = .731). That being the case, what's required is speedometer gearing that will result in the driven gear spinning at 73.1 percent of its current speed. The speedo gear combination for a 2.73 rear (assuming 26-inch diameter tires) is a 17-tooth drive gear and 37-tooth driven gear. Switching to a 45-tooth driven gear (the most teeth available) would translate to the vehicle traveling at 82 percent of indicated speed - still a 10 percent error.
Obviously, the drive gear must be changed to one with 15 teeth if the 73.1 percent ratio is to be achieved. Going back to the original 37-tooth driven gear for illustration purposes, the 15-tooth drive gear would result in the vehicle traveling at 88 percent of indicated speed - that seems like a step in the wrong direction, until the driven gear is changed. (This is where it gets a little tricky because you have to work with a percentage of a percentage). Matching the 15-tooth drive speedometer gear up with a 44-tooth driven gear brings the drive ratio to 74 percent (15/17=.88; 37/44=.84; .88 x .84 = .739, which rounds to .74, or 74 percent). Still not quite enough. Will a 45-tooth driven gear do the job? Run the numbers through your calculator and you should come up with 72 percent. That's about as close as you're going to get.
In case you haven't put all the pieces together, there is a distinct limitation regarding speedometer accuracy and steep rear gearing. Unless driven gears with more than 45 teeth, and/or drive gears with fewer than 15 teeth become available, it will be impossible to have an accurate speedometer with rearend gear ratios lower (higher numerically) than 3.75:1 - unless 27-inch or larger tires are installed.
Q: I want to buy speedometer drive/driven gears, what are the part numbers and combinations?
A: Here is a list of GM part numbers for drive and driven speedometer gears, as well as some combinations that are known to work:
Part No. Teeth Color Sleeve*
25513042 35 Orange 25007338
25513043 36 White 25007338
25513044 37 Red 25007338
25513045 38 Blue 25007338
25513046 39 Brown 25007338
25513047 40 Black 25007339
25513048 41 Yello 25007339
25513049 42 Green 25007339
25513050 43 Purple 25007339
25513051 44 Dk Gray 25007339
25513052 45 Lt Blue 25007339
*Some applications may use Sleeve No. 25007224 or 10456092 in place of 25007338, or 25007308 or 1045089 in place of 25007339.
Red Drive Gear Combinations
With drive gear number 8640517, (red, 17 teeth) the following combinations apply:
Axle Tire Dia. Driven Gear
Ratio (Nominal) (Tooth Count)
2.59 26.0 35
25.7 36
2.73 26.0 37
25.7 38
2.87 26.0 39
3.07 26.0 42
3.31 26.0 45
Gray Drive Gear Combinations
With drive gear number 8642620, (gray, 15 teeth) the following combinations apply:
3.33 25.7 40
3.45 25.7 41
3.54 26.0 42
25.7 43
Lower ratio (higher numerically) rear or smaller diameter tire requires higher driven gear tooth count. Increasing or decreasing driven gear tooth count by one will usually accommodate a 1/4" to 1/2" change in tire diameter.
http://www.thirdgen.org/newdesign/fa...n.shtml#tranny
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Bag you just got
Old 01-13-2006, 06:49 PM
Genopsyde's Avatar
The President
that wasn't meant in a negative way, more like a "did I post that in the last thread or not" type of way.
Old 01-13-2006, 06:54 PM
bag91's Avatar
Needs to be reprogrammed, not all the stuff you just said......
I asked the guy at the shop.....just reprogrammed and Im wondering what I need to do this?
Rally=
K/N filter
3.73's
B&M Megashifter
180 thermostat
3" exhaust cutout
Old 01-13-2006, 06:56 PM
I-ROC KID I-ROC KID is offline
i got out of a ticket ones cuz my speedo was off saved me about 100 bucks
355 small block 4 bolt, 700R4 tranny/w shift kit, elbrock 650 carb, elbrock intake, mild cam, 3.73 posi rear end, 3" cowl hood, 3" exhust, b&m mega shifter, k&n air filter, ac delete
Old 01-13-2006, 06:59 PM
bag91's Avatar
Wow...did you get a fixit ticket?
K/N filter
3.73's
B&M Megashifter
180 thermostat
3" exhaust cutout
Old 01-13-2006, 07:02 PM
Genopsyde's Avatar
The President
Bag, your ecm does not control your speedometer, it's controlled by the VSS (Vehicle Speed Sensor) which is in the tailshaft of the transmission. The guy at the shop is wrong. I've done the exact same gear swap as you. Believe it or not, I know what i'm talkin about here.
Old 01-13-2006, 07:04 PM
bag91's Avatar
No...I dont say your wrong....just he looked and saw what I have.
To fix it your way where do I take it....to a tranny shop or what?
K/N filter
3.73's
B&M Megashifter
180 thermostat
3" exhaust cutout
Old 01-13-2006, 07:05 PM
Genopsyde's Avatar
The President
Just cuz it says "The President" under my name doesn't mean I'm a liar.
