Old 01-13-2006, 04:18 PM
unbe unbe is offline
Coolant Leak near CKP (Crank Pos Sens)
I have a 96 Metro with a 3 cyl M/T.I have a coolant leak wich appears to be coming from my CKP.I first thought that the sensor must pass through a coolant passage but I read my Haynes manual and it doesn't mention draining the coolant to change the sensor.It's not a major leak so I have been putting off the repair but I thought maybe one of you folks might have seen something similar to this and might give me some insight.Thanks
Unbe
Old 01-13-2006, 04:52 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Coolant Leak near CKP (Crank Pos Sens)
its probably the water pump above it leaking
Old 01-13-2006, 05:21 PM
Re: Re: Coolant Leak near CKP (Crank Pos Sens)
Crvett69
Thanks for your response,I double checked the water pump per your advice.It can't see any signs that it's coming from there,using a light and inspection mirror.I looked for trails leading to it and the leakage seems very localized.The only other thing thats wet is the pan bolt on each side of it and the CKP mounting bolt does anyone know if any of these bolts goe through coolant passages?I will look at the pump again in the A.M. when I have better light\weather.
Thanks
Unbe
