Old 01-13-2006, 10:05 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Distributer Question
ok, amid my problems trying to get my '85 back to the land of the living, the distributer is next. It's corroded and has the screwon type caps that 3 of 4 bolts broke in the base of it and the cap is being held in place by vise grips
So the question is does anybody have a reference out there to see if the distributers are the same on all the TPIs or is this another fun learning experience that the '85 has some screwed up design to it in it's 6 month lifespan before somebody woke at GM and said what the hell?
Any other car I would say a small block is a small block and the distributer is interchangable with the exception of how many pins are on the ICM. Going to a swap meet tomorrow to bag one so just want to be sure. I'm pulling mine out tonight to get the gist of how it's set up, but just wnat to be sure.
Thanks ya'll
Old 01-13-2006, 10:18 AM
Link85x Link85x is offline
Re: Distributer Question
Damn wrightz28, i wish i could help you out man. Not enough knowledge yet. Hoepfully someone will chime in here soon...
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
Old 01-13-2006, 11:02 AM
wrightz28's Avatar
It's just all the goofy things they did with the first run TPI for 85, i.e. no fan switch, no maf relays let's use a F'n $800 module piggybacked to the ECM, an entirely different ECM, only. Only thing done right was the beefier cam, not by much but good enough, and that's half my concern, if the gear drives are different. And moslty, are the internals of the ign. set up different since the rest of the engine mgmt is different than succeeding years?
Old 01-13-2006, 11:22 AM
85 was the 1st year and the most complicated huh? You know how that is guess. They put it out there, find out what the buggies were, and fix it for the later years. Damn GM, why'd you do that? Well atleast you got a better cam than the crapola i got in there. Have taken out the distributor already?
Old 01-13-2006, 11:36 AM
wrightz28's Avatar
Planned on taking it out tonight. Now they're talking snow. Never fails, as soon as I start getting the ball rolling on this thing either something else has to be taken care of or the weather takes a dive. meh, piss on it, snow or no snow, it comes out tongiht.
Old 01-13-2006, 12:23 PM
I'm telling ya, it's a conspiracy. Everytime you plan to do something, something always seems to stand in the way, bills, weather, world, you name it. Hopefully all goes well for ya Wright.
Old 01-13-2006, 12:50 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
If you pulling it out just wrap it up in a bag and bring it with you just for peace of mind. I am fairly confident that all of the TPI distributors were the same. The coil isnt mounted on the cap and theres going to be an icm under the cap. Whether or not all years had the same type of icm i dont know. But I would be sketchy about electronics coming from mysterious places anyways so being a paranoid person id replace it.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 01-13-2006, 01:09 PM
wrightz28's Avatar
I did some bouncing around and atleast the 86 &87's seem to all be the same. i have the coil in cap. So Now the only difference would be the ICM set up, there's some with 5 pins out there and some with 7? But I want to say the 7 pin ones are for the carbed motors with map sensors.
Old 01-13-2006, 01:36 PM
on the cap?? weird....My 89 with a tbi has the exact same dist. that i have on my 92tpi. They must of changed stuff around in 88.
Old 01-14-2006, 08:38 PM
wrightz28's Avatar
alright, so pulled the dist. it was a mess
new icm pick up checks ok? 1300 ohms on effect.
no change.
now i've pulled the t/b off and it was full of carbon again. starting to think i'm going to put it in the next egrs gone wild! video?
Old 01-14-2006, 10:01 PM
wrightz28's Avatar
eh, egrs ok so what ever. I'm done with this pos.
oh, lesson lesarned:
when aggraveted and launcheing objects, be sure they steer clear of windows, my garage window seems to be in need of repair, oops.
Old 01-14-2006, 10:05 PM
wrightz28's Avatar
oh, quickly noted oddeties:
1 when the o2 or egr vac. solenoind is disconnected, the ecm go give a rats?
Old 01-14-2006, 10:24 PM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
i remember when i couldnt get my rs to start for days and had fixed everything i knew to fix and it still wouldnt start unless i pulled a spark plug then put it back in i threw the keys at the windshield and busted it....that kinda sucked
Old 01-16-2006, 12:50 AM
wrightz28's Avatar
ok, anywho. went ti the swap buggie, got a new sensor, not the roght one for the car but it works, I htink the one that was on it might actually be the wrong one. now it runs, still has a burp up in the acceleration but is driviable. oh, a big part of the problem was weak ass spark due to a grounded carbon button to the coil, don't know how the hell I missed it but it was burned beyond recognition. I'm highly drunk so mind my typng but it looks like if I replace the dizzy as I intended and the secondary, [lugs and wirse she''ll be ok
Old 01-16-2006, 01:09 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
huh?
