Old 01-13-2006, 07:10 AM
Lurchio's Avatar
Lurchio Lurchio is offline
Decal solution affecting clear coat
I finally remembered to add my decals prior to clearcoating on my latest kit and it appears that where I used Micro sol? (blue one) to aid fitting the residue of the solution has affected the clearcoat sprayed on top.
Not massively but very obvious when you look.
I guess the simple answer is just to clean the body in these areas first but I'm worried about affecting the decals.
Anyone with advise or similar experience?
Old 01-13-2006, 08:25 AM
speedphreak speedphreak is offline
Re: Decal solution affecting clear coat
I just cleared over my decaled Kunny'z Chaser. Used soap and water very carefully over the body...rubbed soap with fingers after letting the decals set over night.
-Chris
