Old 01-13-2006, 12:04 AM
gkh7890 gkh7890 is offline
Speaker/radio problem in 2000 Ext. Cab
My right front door speaker (6.25" - not tweeter unit) went out. I tried to install a new Kenwood 1679 2-way unit but all I could get to work is the tweeter.
Also, it has been awhile, but one day I could only get 1 speaker to work for a half hour or so...this has happened only once. Is there a short in my wiring or some other problem?
Any help is appreciated!
Old 01-13-2006, 07:53 AM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Speaker/radio problem in 2000 Ext. Cab
maybe a loose connection at the head unit?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 01-13-2006, 10:12 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Pull the head unit out of the dash and check all connections. Also check where it comes into the door. If these all check ok, get a Multimeter and do a continuity test from the head unit to the door itself.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 01-13-2006, 10:48 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
it is a common problem with factory radios to have a channel go out, is it bose? if so then you could have a bad amp.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
