Manual transmission drain plug
Yes I was wondering if anyone could help me locate the drain plug for the manual transmission on a 98 cavalier z24 (2.4 engine if it makes a diffrence). I have located the filling point no problem, just can't find the drain plug.
Also one more question: My car calls for the GM Syncromesh manual trans fluid. Prestone and Amsoil have released their own comparable versions of the fluid, but it's synthetic. I've always heard that you could NOT change type of fluid in the transmission between the two (synthetic and regular). Any tips on what I should use and what is the best? Thanks for any help in advance. |
anybody??
Re: Manual transmission drain plug
im not 100% sure on this but i thought they just used like a vacuum pump to suck it all out of where you fill it up at (hence there would be no drain plug)
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM, 1981 Fairmont 6cyl 3 speed 1978 Ford Ranchero GT 302 with a few goodies |
on my 2000 it it is flush against the transmision facing the left front tire and requires an allen wrench
you have to suck it out i do believe but i can look it up tomarrow. i think that you put GL5 in it... but not 100% sure. I'll post again tomarrow
