Old 01-12-2006, 08:57 PM
txmedhs txmedhs is offline
Unhappy minsfire cylindre 6
HI, I have misfire cylindre problem code, but I replaced the inyector 6,
but when turn the key on, the inyector continuos spreeding gasoline, it seems the inyector all time is open, please if you haye some tip, please
letme know, is computer problem???
thanks in advanced
edgar
Old 01-13-2006, 12:15 PM
DRW1000 DRW1000 is offline
Re: minsfire cylindre 6
Not sure but perhaps the wires to the injector is shorting somewhere to effectively apply a signal to that particular injector. Form what i understand one side of the injector is a constant 12 V and the PCM grounds the other side when it wants the injector to activate. Perhaps the ground side has shorted to something. It is possible that the PCM input has latched low as well.
Old 01-13-2006, 01:52 PM
Re: Re: minsfire cylindre 6
You rigth there ground is short, but when disconect the computer (EEC-V) the short ground desapear, do you thing the problem is the EEC
COMPUTER?? in orther to get a new one.
best regard and thanks in advanced edgar
Old 01-13-2006, 07:33 PM
We it certainly could be. I can't really say for sure with the limited information here. I would check obvious things like frayed wires on the PCM harness or bent pins .....
