Old 01-12-2006, 08:52 PM
StealthSnake36 StealthSnake36 is offline
Clank
Whenever i shift from Park to Drive or Reverse i hear a loud CLANK sound. What could be causeing this? is it a lack of oil or trans fluid? how can i fix it....if even possible.
Old 01-13-2006, 03:49 AM
gravis2000 gravis2000 is offline
Re: Clank
Maybe a motor mount/engine brace going bad or loose. Open the hood and have some one check to see if the motor is lifting up when you put it in reverse.
Old 01-13-2006, 12:58 PM
Amerikaner83 Amerikaner83 is offline
Re: Re: Clank
Yeah - it wouldn't do to have your motor get a restraining order from your car! My tranny did that when I swiftly shifted from R to D. My mounts were a bit loose at the transmission and motor, but nothing too bad when I brought it in. So long as it's not rocking the car when the clunk happens, you probably have caught whatever it is in time and not too expensive
Old 01-14-2006, 09:48 AM
Hoags's Avatar
Hoags Hoags is offline
Re: Clank
It may be your C/V joints, kind of like a universal joint on a rear wheel drive shaft. I would get it looked at as soon as possible. If it is a C/V joint you will lose the ability to drive the car. Do not jump on it while driving try to keep your accellerations smooth, the less stress on the joint the better. It may be something other than the C/V's but I would at leasr rule them out.
Good luck
