Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 01-12-2006, 06:35 PM
boydee boydee is offline
2003 TOWNCAR Trunk problem
The relay in the door closes but the trunk will not open or close. The trunk opens with the key. When trunk is closed manually it frequentl does not close the last inch or so. Pressing the remote several times activates the pull down motor and closes the trunk.
The trunk light seemed to go out at the same time (not sure).
The Lincoln Dealer first said it was the pull down motor but when I pointed out the pull down motor works he said it must be the "Module".
$300 for the module, $200 for instalation.
I don't think that is the problem and believe it might be associated with the safety feature that won't let the trunk close remotely if there is an obstruction in the way. Your thoughts will be greatly appreciated.
Boyd
Old 01-21-2006, 07:16 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: 2003 TOWNCAR Trunk problem
Do you know if the trunk has ever accidently been slammed shut? I know that will always be a cause for a module to be damaged.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-21-2006, 09:33 AM
I am sure it has been slammed several times. I know the oull down motor works. When it is closed manually the pull down motor closes it the last inch.
Where is the module located?????
Old 01-21-2006, 02:31 PM
Loekee75's Avatar
It should be under the trunk carpet right where the latch is..if not there, then underneath the trunk lid itself connected to the latch up top.
Old 02-02-2006, 12:09 AM
PantherFan PantherFan is offline
Hello boydee,
I apologize in advance if this is a little too basic, but are you sure your 2003 TC has the full "all the way up / all the way down" feature? Lincoln describes this as "full power deck lid" vs the "power deck lid pull down". Both operate from either the door switch or the remote fob.
I don't know which model you have, but in 2003 the fully functional trunk came with the Cartier package or the Signature with the Limited Edition package (54L). It wasn’t available at all on an Executive. Otherwise you have a trunk release and the last inch or so pull down. I know this has been a point of confusion for many users in the past.
Best of luck on a resolution,
PantherFan
2003 Lincoln Town Car
Signature with Limited Edition package
Old 02-02-2006, 08:27 AM
Thank you for your reply.
Actually, this is the full up/down trunk and it worked well for more than 2 years. There is a safety device that, when the trunk is open and there is something sticking up in the trunk and you try to close the trunk remotely, it will automatically and instantly re-open.
I suspect that feature is defective,however, I don't know where it is located. Also, the trunk lights don't work. The fuses are OK.
Thank you,
Boyd Creech
Old 02-02-2006, 12:57 PM
Hi Boyd,
Then there is no doubt that it should work.
The location of what I think Lincoln describes as "Power Luggage Compartment Lid Module" appears to be located in the trunk on the back wall behind a cover. I would describe it as on the wall that eventually becomes the back of the rear seat.
Maybe this will help. It's a bit confusing and hard for me to follow, but here is the text from the Principles of Operation of the Luggage Compartment Lid Module:
"The luggage compartment lid module receives a voltage signal from the driver door module (DDM) when either the button on the driver door trim panel, the keyless entry keypad, or the transmitter is pressed (Twice on the transmitter). Voltage is then supplied to the luggage compartment lid latch, opening it. There are two switches in the latch. One is mounted by the luggage compartment lid module to sense if the latch is closed. The other switch in the latch is monitored by both modules (Lighting Control Module (LCM) and luggage compartment lid module) and is used for disabling the anti-theft system, which is contained within the LCM. The luggage compartment lid module powers the lid motor to move the lid to the fully open position when it senses the latch has been opened.
Optical sensors within the lid motor are monitored by the module to determine when to turn off power and when circuits should be powered or grounded to the lid motor. When one of the buttons is depressed and the lid open, the DDM sends a signal to the luggage compartment lid module which powers and grounds the correct circuits to the lid motor and lowers the lid until the latch closes. The module senses the latch closing through the lid latch switch that is monitored. At this time, the module powers the closing motor, slowly pulling the lid to a fully closed position. Two switches within the closing motor are monitored by the module to determine when the closing motor is bullied down up. The module has a vehicle speed output (VSO, circuit 679) signal that is used to shut down the system if there is a VSO of approximately 5 KPH or more.
The luggage compartment lid motor is equipped with an optical sensor that the module uses to determine if the trunk lid is closing on foreign materials based on the lid speed. If the module detects this occurring, power and ground will be reversed to the lid motor and the lid will open."
The basic troubleshooting flow goes on to say:
  1. Verify the concern by testing operation with the door trim panel button, key fob button and the door keypad.
  2. Visually inspect for obvious mechanical or electrical problems. They mention checking for "bad grounds straps" specifically.
  3. Then the every popular "connect the diagnostic tool" and look for faults and run the tests.
I hope this helps. I assume your 2003 must be out of warranty already. I have a couple months to go, and I am keeping my eyes wide open these days.
Good Luck,
PantherFan
Old 01-25-2007, 09:15 PM
Hemi34 Hemi34 is offline
Did you get your power trunk fixed?
I have a cartier with the same problem, it will not respond to the keypad or the remote or the button in the door. When I close it manually sometimes it will pull down but most of the time it will not, if I push the remote button sometimes it will pull the lid down. The power lift and close function do not work at all. Any help would be appreciated mine is out of warranty but only has 16000 miles on it, and the nearest dealer is 165 miles away, they are a small dealer and do not have an electrical tech working there.
Thanks in advance, I did pull the trunk stuff out and checked all the connections and the ground by the trunk switch and removed the rear seat and check the one behind it.
2003 Cartier
16387 miles
Old 08-02-2007, 04:28 AM
[email protected] johnmac@ezy.net is offline
I have a similar problem with my 2003 Cartier which has a fully automatic trunk open/close. There is no manual or key alternative. I have pushed down the trunk manually, as I have done normally, when it will pick up the lid and pull down to fully closed. I have somehow missed the first notch and picked up the second and the lid is about 1 inch from fully closed. There are a lot of clicks when I push the remote devices (3) but the unit will not release nor fully close.
Can someone tell me what can be done to reset the unit.
Access to the trunk from behind the seat is not possible. There is a "module" behind the seat back, but I dont know if it is the one. It seems that you should be able to release the locking mechanism in case of such a situation.
I would certainly appreciate any help on this matter.
I shudder to think what would happen if a child had got in there or something unable to pull the release.
