Koyo R1751
first of all, is that for sure the correct radiator for 1995 KA24DE? ive found like 2 places where they said only S13, but like 5-10 that say S14. so i think its S14, but if anyone knows for sure before i bid on ebay?
ebay auction and i think i should get the double electric fan setup, from SPL i guess.. how is the FAL 210 vs FAL 220. the 210 has an adjustable thermostat, 220 does not, is the one without it always running full blast if you dont rig up a thermo? is the thermostat just something thats going to break in a couple months anyways? and the fitment with those 2 things are cool right? i assume so unless your motor mounts are broken and you drive hard, that could be bad.
![]() "I got that hustle in my genes like high blood pressure" -E-40 |
Re: Koyo R1751
XAT Racing says the FAL dual will fit perfectly on both models.
i just so happen to have the FAL fans...and i just so happened to install them this past weekend...(finally...lol) As far as fitment goes on a koyo radiator...they fit PERFECT but when it came to mounting it to the rad itself, i had some problems...the holes for the mounting on the FAL fans are different on the koyo (unless the ones i have are custom made...dunno) but i didnt have the big of a problem...maybe if i get time, i'll post up some pictures of them on there...but the fans come will all the hardware need...and some
Current cars: 83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5 |
Re: Koyo R1751
do you have the ones with the thermostat?
Re: Koyo R1751
I know the S14 SR Koyo works fine in an S13...
You should be good to go. The biggest differences will be that the Overflow outlet is pointed the wrong way and the brackets may be slightly off. |
Re: Koyo R1751
no i have the 210's, 210's dont come with the thermostat..the 220's do...one of the websites are wrong...dont remember which one though...(shrug) 210's just come with a relay, and enough hardware to wire up to the a/c system electrical
my dad works at flex a lite. fal is a subdivision. if you have any questions just pm me or reply
www.myspace.com/sileighty461 |
Re: Koyo R1751
can you get me any good deals
Re: Koyo R1751
ok im gonna go ahead and get the koyo racing rad. and the fans w/ thermo. hopefully i can get someone to do the wiring for me.
do you have any kinda of electric fan right now? becuase if you do the wiring up of the FAL is easy breezy
Re: Koyo R1751
stock there is 1 small electric fan.
Re: Koyo R1751
Re: Koyo R1751
i think it is on even with the AC off. it was pretty hard to see, but i remember checking it out with the engine running and it seemed to be going..probably at half power or something
Re: Koyo R1751
Mine doesnt move when my a/c is off, and moves when its on
-Matt NISMO ![]() 1992 240sx SE Fastback 5speed ![]()
Re: Koyo R1751
really? ok thanks. either...optical illusion (looking through part of the other fan..) or mine was fucked up. lol. but thanks for the heads up
