I have a 90 crx and found some interior panels and stuff from an integra. does anyone know if these parts would swap? also would a rear disk assembly from an integra sawp out to the crx?
Re: Integra interior fit in a crx?
I know somebody that put rear disc brakes on his CRX and I think they were from an integra but not 100% sure and I don't know how hard it was to do.
2. Yes, as well as the master cylinder and booster assembly, that way you will have the hydraulic pressure to make the brakes stop PS oh yeah, once you put the bigger discs on the back, your stock 13"s will not fit.
Rest In Peace, Rich Hall my baby: 1986 Fiero GT: v6, automatic, 2.8L, 2.02/1.60 heads, Crane Performance Cam, Ported/polished exhaust manifolds, taylor plug wires, low temp thermostat and fan switch. WCF catback exhaust She's done!
Re: Re: Integra interior fit in a crx?
the interior, is not worth making fit, it'll end up looking shitty in the end anyway unless you are pretty good with fabrication. there is no real need to replace the master cylinde, it will help a bit, but its not a big deal, its only like 1/8 bigger or something, not much. what you really do need is the prop valve from the integra to get good pressure to the rear, you'll also need ebrake cables and rear brake lines for disc. and unless the rear brakes on a integra are bigger than 90-91 crx si,and im 99% sure they arent, 13's will fit with no problem, i had them on my crx.
Saturn Stealership Technician #331 |
