Old 01-12-2006, 03:21 PM
jeff55 jeff55 is offline
LeSabre code PO 440
engine light came on-trip to auto zone and they gave me the code PO 440. They had no description of the problem Anybody know what this code means???
Old 01-12-2006, 05:01 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: LeSabre code PO 440
PO440- Evaporative emission control system malfunction
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-12-2006, 06:16 PM
maxwedge maxwedge is offline
A990 racer
First place to concern your self is a loose gas cap or one that won't seal properly, after that it gets real complicated.
Old 01-12-2006, 09:05 PM
imidazol97 imidazol97 is offline
AF -Advisor
Check seal on gas cap. Coat with vaseline. Rub inside of filler on tank where the rubber seal mates. If rough with brown coating, rub with oil or vaseline to smooth for good seal.
The car may not check for correct vacuum seal on tank until the car is luke warm, and then is restarted. I think it was something like coolant warmer than 120 and cooler than 170 when I dug through the service manuals for my 98 LeSabre. When you restart like that it may be 30 seconds and then the light will go off if it is now a sealed system that holds vacuum lone enough to pass the test.
