Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '93 - '96
Old 01-12-2006, 02:32 PM
VW_kng VW_kng is offline
Windows not working!!!!
None of my windows are working in my 94 VR6. I put a new fuse in and still nothing. I'm figuring it has to be a wire somewhere since none of the buttons wok, from neither the front console or each individual door. Maybe a wire from the fuse box????? Also, this problem is intermittent. Sometimes the windows will roll down, but most of the time not. Please help!
Old 07-07-2006, 01:30 AM
stinaVR6 stinaVR6 is offline
Re: Windows not working!!!!
Same here. I believe it's just called a power window switch??? Cheap part. Most part stores carry it. I'm just to busy fixing everthing else on the car to worry about the windows much.
Old 12-20-2009, 05:58 PM
misfitmaster misfitmaster is offline
Try opening your driver door and seeing if the windows will go down.Sometimes the switches inside the doo jam will not work right.Also check in the door jam where the wiring goes through the door into the car.Sometimes he wires will actually break inside there and not work.Hope this helps!
