Old 01-12-2006, 12:29 PM
mo9 mo9 is offline
Diver window stopped working suddenly
Please help my drier window in my 98 blazer just stopped working. I thought it might be a fuse, but I saw hear it has a circut breaker. It is as simple as flipping my house circut breaker? ha ha ha . Please help
Old 01-12-2006, 01:07 PM
Blazer SS Blazer SS is offline
Re: Diver window stopped working suddenly
Check one thing first. Check the connection on the drivers side window button. It could just be loose from opening and closing the door.
Old 01-12-2006, 01:52 PM
mo9 mo9 is offline
Re: Re: Diver window stopped working suddenly
Thanks for responding so quickly...I kept pressing forward and back(to move it up and down) and it does not feel loose.
Old 01-12-2006, 02:28 PM
biv343 biv343 is offline
I think he means remove the button and make sure the wires are still connected to the bottom of the switch. While you've got the switch out, might as well check it with a continuity tester and make sure the switch is still good (which it more than likely is, unless it repeatedly gets wet and is corroding inside).
Old 01-12-2006, 02:42 PM
Southern Comfort's Avatar
Southern Comfort Southern Comfort is offline
Do what BlazerSS says. He's right on the money with his diagnosis. My 99 did the same thing, mine started working again the next day. Went out again about a week later, and the same thing, it started working again. There's a circuit board under the buttons. Look for a cold soldier joint( Loose connection) on the wire connector or circuit board.
Thanks
SC
Old 01-12-2006, 05:26 PM
TheBrettster TheBrettster is offline
AF Premium User
wierd last friday mine went out. it would not work but then all of a sudden it started to work yesterday. it scaried the crap out of me.
Old 01-12-2006, 05:27 PM
jsgold jsgold is offline
If your buttons check out OK look inside the wire boot between your door and your cab. I have seen the wires in there break from opening and closing a lot on other vehicles. Just a thought.
I used to be indecisive, now I am not so sure.
Old 01-12-2006, 08:46 PM
blazer321 blazer321 is offline
If it doesn't look like it is an electrical problem try taking off the door panel. my drivers side window didn't work, one of the rivots came off of the window motor and was jamming the window. which prevented it from opening.
Old 01-13-2006, 08:35 AM
mo9 mo9 is offline
Re: Re: Re: Diver window stopped working suddenly
Thanks
SC
Ok this is going to sound very silly, but do I have to take the whole door off to check for the loose connection.
Old 01-13-2006, 08:49 AM
Re: Re: Re: Re: Diver window stopped working suddenly
You don't have to take the door off, the little plastic piece that your buttons are on just lifts up. Start at the front of the plastic(towards your dash) and lift back towards the seat. Lift it gently, and there you'll have access to your circuit board and relay and connections.
Thanks
SC
Old 01-13-2006, 10:48 AM
dbldown768 dbldown768 is offline
actually i have the same year car and had the same problem. i used a voltmeter and check all the circuits and everything was fine. I then removed the door panel and while pressing the down button on the circuit board i tapped the motor with a ballpean hammer - all the sudden the window works.
However now i know when its going to get jammed. If i roll up the window and normally you know how a windows stops when closed, well before mine stops it makes like this click noise in the door. if that happens i back the window up a bit and has been fine ever since. Its a huge pain in the ass though and would like to fix it some day somehow. Im thinking its just the motor.
Old 01-13-2006, 10:58 AM
Sounds like the motor to me as well. I know those motors and the fuel pump motors can get carbon deposits between the armature and brushs
and cause this problem. You could take the motor out and take it apart and sand it with 800 or so sand paper, blow it out with air and that will fix it. I did that to mine and it's been working ever since. No more problem.
SC
Old 01-25-2006, 02:47 PM
jmagerl jmagerl is offline
The driver side window stopped working on my 96 after about 60K miles. IT was the motor. If you held the switch down and pounded the door with your fist, you could jog the motor into working for awhile. Eventually had to replace the motor. IT wasnt easy but it wasnt too bad either. The hard part was removing the rivets that held the motor in place and finding replacements. Not having a big enough rivet tool I ended up using bolts and grinding the heads down to get the desired clearence. that was 120k Miles ago. hasnt failed since.
Old 01-26-2006, 04:43 PM
534BC 534BC is offline
My pass window has "not gone down" about 2 times per year for about 4 years. It is the motr and usually the fix is to either rev engine slightly and turn off lites. Or to open and close door, then it works.
Old 01-27-2006, 06:56 PM
GirlBear's Avatar
GirlBear GirlBear is offline
Mine does that too sometimes. I just punch the panel on the side of the door underneath the buttons. works every time!
http://jowulf.deviantart.com/
