Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-12-2006, 10:01 AM
SKELLEN98 SKELLEN98 is offline
94 Jgc Info Center
My 94 Jgc Ltd Info Center Says I Have A Rear Brake Light Out And I Have Inspected All Bulbs For Burned Fillaments And Proper Application And All Seems Correct.is There Any Self Test I Can Do To The Info Center Module?
Old 01-12-2006, 01:22 PM
teemsta teemsta is offline
check to see if your 3rd brakelight is out. I also had the same problem,vic telling me bulb was out but all worked. ended up being one ofthe brake light bulbs. the contact points n the bul was worn down and there was no good connection. try replaceing the brake light bulbs.
Old 01-13-2006, 03:10 PM
Re: 94 Jgc Info Center
Thanks For The Suggestion. I Will Try New Bulbs Thru Out The System And Let You Know.
Old 01-13-2006, 03:41 PM
bringselpup's Avatar
bringselpup bringselpup is offline
A year ago the VIC was blinking it's evil message at me "rear lamp failure" and I looked time and time again and not one light was dead. I finally got so frustrated I opened both tails and pulled every bulb to swab them with bulb grease. Lo and behold I had a nasty corroded bulb in there. It was still lit, but it wasn't until I pulled it to cover it with the grease that I saw the base was all loose and wobbly.
The VIC hasn't made a peep about lights since I replaced that one.
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
Old 01-13-2006, 03:56 PM
THANKS ILL TRY THAT THIS WEEKEND
