Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-12-2006, 01:29 AM
jbluesi's Avatar
jbluesi jbluesi is offline
tsi wont start
this is for my friends 92 tsi, it ill start from the begining, he was really stepping on it one day and the timing jumped and he ended up ruining his bottem end, so he got a new moter with a 16 g turbo on it, hooked up to a ported and polished head on a non turbo block on low boost, the shop that put it in let a kid from a school program work on it and he ended up hooking up the battery wrong and frying some fuses, now the car wont start, it turns over, there is spark, but there is no pulse getting to the injectors, their getting power but they're not working. he bought another ecu but still the same problem, no more blown fuses, or relays. is their an obvious problem or is it some annoying dam sensor thats messing it up. need some help bad
Old 01-12-2006, 02:31 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: tsi wont start
Might be a short in the wiring harness.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-12-2006, 10:15 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: tsi wont start
I agree it sounds like a short. You can do what i just did and take apart the entire wiring harness to track down the problem. You may fnd some fried wires somewhere. BTW why woould the fucking shop let some kid fuck with his car? shouldn't they be the ones fixing it?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-12-2006, 10:26 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Re: tsi wont start
Probably a work study type program or an aprentaship(sp). I had this problem on a cherokee that I was working on. injectors had power but werent pulsing. ended up being a bad driver circut. Injectors always have power, the thing that makes them pulse is they get grounded most of the time its in the pcm but I'm not sure on the specifics on a talon. since you already replaced the psm I would have to agree with ez since you dont really have testing tools I'm guessing, you'll probably have to do it the hard way and track down the harness. If you happen to have a digital multimeter(if you dont you can buy one at sears for $20) you can test the injectors to see if they are getting grounded and if they are then you probably have a problem somewhere else in your fuel system, maybe a bad pump or pluged filter or something along that line. Good luck
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-15-2006, 12:19 AM
jbluesi's Avatar
Re: tsi wont start
is there any kind of messed up sensor that could cause this type of problem
