The New GT500
Well guys it kind of seems like Ford is listening to you. the GT500 that was unveiled at the detroit auto show had 475hp up from the 450 estimates from before, and it is mated to a 6 speed manual. im not sure where the extra horsepower comes from, if they are still using the single screw or not. people on here were wishing it had more power and a 6-speed, now both have happened (i know the power increase isnt that much...) what are your thoughts? am i posting up out of date information?
i didnt see anything about the weight of the vehicle. edit- ahh damnit, it seems jaguar d type already posted all this... Last edited by TheStang00; 01-11-2006 at 11:33 PM. |
Re: The New GT500
i like it. its way too heavy though
Re: The New GT500
It's a sweet car but it's defitnetly way to heavy and for the price it's out of the question. Look at the new z06 now that's one fast car and you cant beat the price.
1995 PONTIAC TRANS AM LT1 6SPEED.
Re: The New GT500
Has there been any change to the estimated 40,000 it was supposed to cost? I am not a fan of more weight but it only weighs a couple hundred more than the last cobra and its got 475 hp stock. Its also built more solidly than the last generation. I still like it alot.
Here is the specs
BODY Construction Unitized welded steel body, aluminum hood POWERTRAIN AND CHASSIS ENGINE Type: V-8 Manufacturing location: Romeo, Michigan Configuration: Iron Block and Aluminum Heads Intake manifold: Cast-aluminum with Roots-type supercharger and air-to-water intercooler Exhaust manifold: Cast iron Crankshaft: Forged steel Throttle Body: Dual 60 mm, electronic Valvetrain: DOHC, 4 valves per cylinder Valve diameter: Intake: 37.0 mm; Exhaust: 32.0 mm Pistons: Forged aluminum Connecting Rods: Cracked forged steel I-beams Ignition: Coil-on-plug Bore x stroke: 3.552 x 4.165 in. / 90.22 x 105.8 mm Displacement: 330 cu. in. / 5,409 cc Horsepower: 475 (estimated) Torque: 475 lb.-ft. (estimated) Compression ratio: 8.4:1 Redline: 6,250 rpm Idle Speed in Neutral: 750 rpm Engine control system: Silver Oak PCM Recommended fuel: Premium only Fuel capacity: 16.0 gallons Fuel Injection: Electronic returnless sequential Oil capacity: 6.0 quarts 5W-50 Full Synthetic Coolant capacity: 21 quarts DRIVETRAIN Layout: Rear-wheel drive TRANSMISSION Standard (Type) Tremec TR6060 6-speed manual Gear Ratios 1st : 2.97 2nd : 1.78 3rd : 1.3 4th : 1.0 5th : 0.80 6th : 0.63 Final Drive: 3.31 SUSPENSION Front: Reverse-L independent MacPherson strut, 34-mm tubular stabilizer bar Rear: Three-link solid axle with coil springs, Panhard rod, 24-mm solid stabilizer bar STEERING Type: Rack and pinion with power assist Ratio: 15.7:1 Steering column: Tilt BRAKES Type: Four wheel power disc with 4-channel anti-lock braking system (ABS), electronic brake force distribution (EBD) and traction control Front: Brembo 14-inch diameter vented discs, four-piston aluminum calipers Rear: 11.8-inch diameter vented discs, two-piston calipers TIRES AND WHEELS Tires: P255/45R18 front tires, P285/40ZR18 rear tires Wheels 18 x 9.5-in machined aluminum wheels with SVT center caps DIMENSIONS (inches unless otherwise noted) (All dimensions are Preliminary) EXTERIOR Wheelbase: 107.1 in. Overall length: 187.6 in. Overall width: 73.9 in. Overall height: 54.5 in., Coupe; 55.7 in., Convertible Track width, front/rear: 61.9 in. / 62.5 in. Ground clearance: 5.71 in. INTERIOR Seating capacity: 4 passenger Headroom Front row: 38.6 in., Coupe; 38.8 in., Convertible Second row: 35.0 in., Coupe; 36.3 in., Convertible Legroom Front row: 42.7 in., Coupe; 42.7 in., Convertible Second row: 31.0 in., Coupe; 30.3 in., Convertible Shoulder room Front row: 55.4 in., Coupe; 55.4 in., Convertible Second row: 53.3 in., Coupe; 45.0 in., Convertible Hip room Front row: 53.6 in., Coupe; 53.6 in., Convertible Second row: 46.7 in., Coupe; 45.4 in., Convertible Cargo Volume: 12.3 cu. ft., Coupe; 9.7 cu. ft., Convertible WEIGHTS AND CAPACITIES (pounds unless otherwise noted) Curb weight, pounds- Coupe ~3,920 pounds Convertible ~4,040 pounds Weight distribution: (f/r) 57/43 SAFETY Safety belts: Load-limiting seat belts with pretensioners and height-adjustable shoulder belts for front seating positions (coupe) Three-point safety belts for all seating positions BeltMinder™ safety-belt reminder chime Air bags: Dual-stage driver and front-passenger air bags with crash-severity sensor, driver-seat-position sensor and front-passenger weight sensor Seat-deployed side air bags for driver and front passenger Child safety: Childproof rear door locks LATCH anchors for rear outboard seats Brakes Anti-lock braking system (ABS) Traction-control system Fuel: Inertia-activated shutoff switch for fuel pump Security: SecuriLock™ passive anti-theft system Remote keyless entry Separate alarm sounder Anti-tow sensor Ultrasonic interior motion sensor Perimeter anti-theft battery MAJOR STANDARD EQUIPMENT Audio system: Shaker 500: AM/FM stereo with six-disc CD/MP3 player with eight speakers EXTERIOR Badging: Unique GT500 Top: Black cloth (Convertible only) Exhaust: Tuned dual stainless steel Fascia: Unique GT500 color-keyed front and rear Fog lamps: Front Grille: Unique upper with Cobra emblem Hood: Unique with heat extractors Locking: Remote keyless entry Spoiler: Unique color-keyed decklid spoiler Trim: Over-the-top "LeMans" stripes and "GT500" side stripes (Coupe) "GT500" side stripes (Convertible) Trunk: “Fix a Flat” tire repair kit INTERIOR Air conditioning: Manual Console: Center with full armrest and storage Cupholders: 2 Door trim inserts: Soft vinyl Floor mats: Front, color-keyed with driver-side retention hook Instrument cluster: Includes boost gauge and message center, SVT graphics Map pockets: Front doors Power points: 2 Scuff plates: Door sills, with bright SVT script insert Seats: Leather sport buckets; 6-way power adjustable driver seat with power lumbar and 2-way adjustable head restraint Shift knob: Unique with leather shift boot and parking brake handle Steering wheel: Leather-wrapped with unique thumb pads, adjustable for tilt Windows/door locks: Power OPTIONS DELETE OPTIONS "LeMans" stripes: Coupe only "GT500" side stripes: Coupe, Convertible AUDIO Shaker 1000: 1000 watt audio system: AM/FM stereo, in-dash six-disc CD/MP3 player, 10 speakers Satellite radio: SIRIUS PACKAGE GT500 Premium Interior Trim Package: Wrapped and stitched instrument panel brow and center condole with upgraded door armrest, electrochromic rearview mirror and aluminum pedal covers EXTERIOR/INTERIOR COLORS EXTERIOR Paint/stripe colors: Torch Red Clearcoat with Performance White or Satin Silver stripes Alloy Clearcoat Metallic with Satin Silver or Tungsten stripes Vista Blue Clearcoat with Performance White or Tungsten stripes Performance White Clearcoat with Vista Blue or Tungsten stripes Tungsten Grey Clearcoat with Satin Silver stripes Valencia Yellow Clearcoat with Tungsten stripes Ebony Clearcoat with Performance White or Tungsten stripes Convertible top Black cloth INTERIOR Charcoal Black/Charcoal Black Charcoal Black/Crimson Red WARRANTY INFORMATION Warranty 3-year, 36,000-mile bumper-to-bumper limited warranty
The ///M stands for Motorsports
Re: Re: The New GT500
Re: The New GT500
Well I am sure they will sell. They fill a niche right now. They really don't have any direct competition, other than the concept camaro and concept challenger that may come in the future. The new mustangs are selling like crazy and I know there will be people out there that will spend the extra to have the most powerful one out there.
Re: The New GT500
i dont really think you can argue that the new mustangs are selling well... i dont have the numbers on hand but its kind of a given. the dealers dont want to run out so they order extra. the new mustang hasnt been out to much more than a year and i see tons of them, its doin pretty good. the rest of the car market is what ford needs to worry about selling, not the mustang.
Re: The New GT500
Like I said there are always at least 15 new ones and 5 used one on the lot. That means 1 in 3 ends up being traded in within the first year. That realy isn't good odds if you think about it. Sure it means sales but it also means a lot of people aren't happy with them for one reason or another. Odds like that tells me there must be something wrong with it. Only time will tell what that those problems really are when the newness of the car wears off and real review start coming in.
Re: The New GT500
not trying to argue your point at all, i just saw the top gear with the new mustang, while it may not be the newest episode idk, they said a mustangs average shelf life on a lot is 15 minutes. i thought that was pretty impressive, although not much else on their review was.
i think you have some valid points though. it could be people that bought a v6 and didnt get the performance they wanted, in that case they are idiots for buying that version. also whenever a new car model comes out there are always problems with it, a large portion of these trade ins could be people who are sick of finding the little problems of a new car. ive heard of this happening with the new cobalt, they had some serious problems at first. if i remember correctly it also happened with the focus its first two years. just some thoughts |
Re: The New GT500
40k isnt bad...i hav a pic of an 06 Si set at 34k after 13k markup LOL
and the focus had MAJOR RECALLS lol i do think the v6 mustang is under powered, a sporty v6 needs 230hp minimum now adays. there are 7 used 05's total in 3 local lots, v6's and GT's
FORMERLY: zx2srdotnet(1,380 posts) 2001 Esxort ZX2 - Traded 2000 Escort ZX2 S/R - Sold 2003 Mustang Mach1 - Totaled 2014 Altima 2.5 S - Purchasing Soon |
http://cec.wustl.edu/~ljm1/personal/...Mustang4-2.avi I just found the first real review (and its a Clarkson review) of the 05's its nothing held back and even has a track test done at Laguna Seca. I couldn't agree more! This is the same impression I got when I test drove one. http://driving.timesonline.co.uk/art...4313_1,00.html "By European standards this car is rubbish. Its engine has wasteful, unused capacity that turns fuel into nothing, it couldn’t get from one end of a country lane to the other without running out of brakes and it handles like a newborn donkey. So what’s it like to drive? Well, the previous day I’d taken it on a hard lap of the extraordinarily beautiful Laguna Seca raceway, which, because it’s the curliest track in North America, is regarded by racing drivers all over the world as one of the greats. Mansell. Villeneuve. Even Top Gear’s Stig go all misty eyed at the mention of it. And frankly it was more than a match for Ford’s big daft horse. Its brakes were cooked by turn six; the final slow corner completely overwhelmed the live rear axle; and through the fearsome Corkscrew, which twists down a gradient so steep you can’t even walk up it, I’m afraid Mr Ed was about as pin sharp as a punt gun. "
Re: The New GT500
heh i was well aware of the review... lol
Re: The New GT500
I cant wait!!! Its exciting to see this car making a come back.. You guys here about the CS6 stang Shelby is putting out.. they are comparing it to the GT350...nice styling....
Meet JazLynn........ ![]() ![]() ^ A friend will help you move but a real friend will help you move a body ^ |
