Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-11-2006, 10:44 PM
gravdigah gravdigah is offline
Angry No Spark No Fuel No Start
I Have a 91 TSI Talon I have no spark no fuel! Car Wont start and I'm getting pissed. Fuel pump/ECM Relay seems to Work. No blown Fuses, I have no power at the Crank angle Sensor but I do have power going to the coil pack and the module. Please help i'm a new talon owner and dont know what the usual problems are.
Old 01-12-2006, 10:08 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: No Spark No Fuel No Start
How about the ecu? Did you check that? You can take the cover off and have a look sometimes a resistor or capacitor will leak and fuck your ecu. That may cause similar problems.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-13-2006, 05:56 PM
Re: Re: No Spark No Fuel No Start
Already Checked that No go. Everything looked fine. Thanks For the Response though.
Old 01-20-2006, 12:26 AM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
did you take the ecu out and look front to back, i know mines looked fine from the front but when i turned it over it was fucked,, heres some things to check for,
1. check wiring and fuses/relays to the starter motor
2. check wiring fuses/relays to the altonator (also make sure the starter and altonator are getting 12volts!)
there is no reason i can think of to why your car wont get fuel due to a bad crank angel sensor. im thinking its a bad Ecu even if it looks fine there could be a issue, umm talk to to a shop and let them check it out, or learn to use a voltameter and get codes and go from there,
