Old 06-12-2002, 12:17 PM
spotovi spotovi is offline
Questions- HP Gains
Hi All,
I'm confused. OBDI has HP gains of 5-20hp with a Cat-back installed depending on the setup. This is information from what I gathered around the internet. Now, OBDII has HP gains of 2-8Hp with a Cat-back. Is this true? Why the difference? I don't understand the difference between OBDI and OBDII. The only thing that I know about it is that there is 2 oxygen sensors in OBDII equipped vehicles. Some Tech information will be great. Thanks.
Regards,
Spotovi
97 Integra, 10th Anniversary Addition.
(RS with Non-Leather GSR interior)
B18B
K&N CIA
Custom Bent SS Cat-Back w/SS Dragon Style Muffler (4.5 Inch tip).
Stock Suspension
Stock 14" wheels
Goodyear Eagle HP
Stock Brakes
Old 06-12-2002, 07:10 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the thing with OBDII is that it has more sensors to keep emissions even lower than the OBDI did, so the more sensors to control emissions and stuff, then the less the HP you will gain through the speed parts added.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-12-2002, 10:23 PM
Thanks for the info.
Is there anything that I can do to bypass these controls and still be within legal tolerences? I guess reprogramming will do the trick right, will it be that simple?
Regards,
Spotovi
B18B
K&N CIA
Stock Suspension
Stock 14" wheels
Goodyear Eagle HP
Stock Brakes
Old 06-13-2002, 02:50 AM
tenzoracerevovii tenzoracerevovii is offline
i don't think so.....the sensors send signals to the ecu to adjust shit....A/F ratio and stuff like that....if you bypass those, the ecu will probably just richen out the mixture to prevent detonation.....and that will make your emissions be very bad.....so i think you'll just have to live w/ it.....
i have type-r stickers on my bike, will it go faster?
-me
Don't you know, it's 10 hp for every sticker, 50 hp extra for every additional inch of rear spoiler behond stock height.
-obiewancoyote
Old 06-14-2002, 02:48 PM
crxlvr's Avatar
you may be able to tune it so it runs better than it currently would run, maybe using the HonData system, but those are pricey.
you will prolly end up having to live with it.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-25-2002, 11:53 PM
stefan525 stefan525 is offline
Send a message via AIM to stefan525
get a OBD II - OBD I harness and run an OBD I ecu, then you will have less codes you have to worry about and more hp gains. Just make sure you get the right ecu. good luck. stefan525
Old 06-26-2002, 08:25 AM
Thanks stefan525. I'll look into it. However I have a feeling that if I change the OBDII system to OBDI the car will not pass the emissions here in Hamilton, Ontario. The system is set for the year of the car etc and if OBDII systems have lower emissions then they will expect my car to be within those same tolerences. I'm just guessing though and it will be a point that I have to research before I get started with something like that.
I understand that the ECU is a control device etc, but for discussion, if I where to take the fuse for the ECU out and run the car without an active ECU will I have a bump in HP?
Regards,
Spotovi
B18B
K&N CIA
Stock Suspension
Stock 14" wheels
Goodyear Eagle HP
Stock Brakes
Old 06-26-2002, 01:52 PM
No. Your ECU is the brain of the car. It figures out air/fuel mixture, reads the imputs from the O2 sensors, delivers imputs to the fuel injectors, etc. So you need your ECU in order to be able to run your car. good luck. stefan525
Old 06-26-2002, 02:20 PM
crxlvr's Avatar
yeah if u disconnect the ECU ur car wont even turn on.
you may be able to get a chipped ecu that helps to gain HP.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-26-2002, 02:29 PM
1320B4U 1320B4U is offline
Is a 1997 GSR OBDI or OBDII?
Old 06-26-2002, 03:00 PM
97teg 97teg is offline
96+ is obdII.
