Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-11-2006, 07:56 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
High reving 2.0 or torquy 2.3?
I'm eventually going to build a motor for my talon but I cant decide if I want to build a 2.0 or stroke it. this is going to be a dd afterwards so it had to be totally streetable. I know this is kind of a personaly opnion type of question but input would be nice as to which you personally would do and why
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-11-2006, 08:20 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: High reving 2.0 or torquy 2.3?
2.3 or 2.4. u can run a gigantic turbo and still be streetable in terms of spool
now - 2000 civic
soon - 2002 is300
Old 01-11-2006, 09:38 PM
inatalonIXLR8 inatalonIXLR8 is offline
I'm going stroker. Unless you are serious about drag racing, I would go this route. You'll have a power band that you'll use more as a daily driver and with all that extra air flow, as crunchymilk55 said, your turbo will spool alot quicker. This will give you way better bottom end.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 01-11-2006, 09:52 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah dude, I would do a 2.3. I am, however going to do stock rebuild. Stock bottom ends can take more power than I will be putting down so I cant justify spending $1000 more for the stroker. My plans are as follows. Get a 1g, stock rebuild on the bottom end, FP2 or FP2x cams, dual springs and TI retainers, a SBR 50 trim, cheater juice, DSM link, and all the other stuff, basically my goal is a high revving 2.0.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-11-2006, 10:12 PM
blk_srt's Avatar
Re: Re: High reving 2.0 or torquy 2.3?
Originally Posted by Thor06
cheater juice
lol I like that idea
Mods:
Old 01-11-2006, 10:32 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
why not a high reving 2.3 liter? aslong as the roating assembly is ballenced well and your head is spewing titanium out the ying yang you should be good for 9k rpm.
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 01-12-2006, 12:07 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Wheres Shpyder when you need him...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-12-2006, 03:52 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
It's just not safe to rev past 8000 rpm's on a 100mm stroker DSM. The extra 12mm stroke creates to high of piston speeds.
You won't need high seat pressure dual valve springs for any Comp/Zex cams below FP3's. Even the FP2x cams will run fine on stock springs. When you get into the high lift FP3's and 4's you'll require 90lb seat pressure. But other then that. The stock head with fp2 cams are reliable upto 8500 RPM. If you want to take a set upto 9500 any performance HKS, Crower, Ferria valve components will do.
If you think about it. A stroker isn't that expensive. You can get a good used unground crank for $150 if not cheaper. Weisco 2.3L pistons for $350 on ebay. Combined with $40 ARP rod bolts and 1g rods machined to perfection you got a 500hp ready block. assuming everything else is done right and you dont use Clevites new Aluminum bearings.
DSM geek
Old 01-12-2006, 10:36 AM
kjewer1 kjewer1 is offline
AF - Advisor
I've run several of both size motors, and for a street car I'd do a stroker without question. If high reving is a necessity (it's not for a street car) do magnus' long rod stroker. They are going to 9k on those. On my regular rod stroker I had the rev limit set to 8500 and shifted at just over 8k most of the time. When going with a stroker though there are many other considerations to take into account on the rest of the setup though. You wouldn't run a 14b on one since it would practically max out at the stock WGA pressure, but I see poeple do it. Kinda pointless Get a larger turbo since it will still spool well, and think about the exhaust side as well. The larger displacement gives a 15-20% increase in airflow, so you also need to increase the exhaust flow to accomodate that, and no one seems to think of this in thier buildup. 15-20% more air also means 15-20% more fuel at the same boost, so take that into account as well. So the added cost is not only in the actual stroker parts, but also in the supporting mods. But well worth the effort in my opinion.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-13-2006, 09:22 AM
Magnus makes that long rod hit 9000 rpm? Nice! I had no idea. Is it too early to add this to my christmas wish list for next year?
Old 01-13-2006, 09:47 AM
AF - Advisor
Not considering the price! You mightwant to add it to your christmas list for 09 If I ever rebuild my motor it's getting the magnus kit. Of course that requires the 2.4 block though, so I'm really not using anything from the old motor but the crank
Kevin Jewer
Old 01-14-2006, 12:45 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
I agree. Unless youre a serious drag racer every time you drive, a stroker makes more sense. A high revving block, like the one I just installed, would require an upgraded tranny to sustain a 10,000 RPM shift, plus a bazillion other things, to actually take advantage of the high rev tolerance of the motor. A stroker would make more power in the daily driving RPM range than my motor. I would have gone stroker had it not been for the deal I got on the high-rev SBR block. Not that I'm not lovin' every bit of it right now!
The daily driver. The weekend cruiser. The lazy shop hog.
