Old 01-11-2006, 05:19 PM
Seanf1 Seanf1 is offline
Angry Eclipse Vibration
I am a new owner of a Eclipse Spydor 2005 and I have a inconsistant vibration at speeds over 50mph. I'm 300 miles away from the nearest dealer. I've had it in just a few weeks ago and they looked at it and said I had out of round tires so Good Year replaced all 4 tires and I still have the same problem. There has been 5 different tires stores that have spin ballanced the tires and Good Year did after the new tires went on. I'm tiered of the BS stories from the dealer telling me to bring it back. All of my milage is being put on to and from the dealership. All the tire delaers have found no sign of a bent rim either but not sure if they have looked for it. I'm wondering if an alignment would help? Or may be I have a out of round rim, I'm not sure just looking for some help. Thanks
Sean
Old 01-11-2006, 05:33 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Eclipse Vibration
Alignment should have been done when the new tires were put on. You may also have bad struts. Bad struts will cause the wheels to not turn right, causing uneven wear and noise. I got the same problems.
Get an alignment, or at least get it tested to see if it's needed. If not, then check the struts.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-11-2006, 09:38 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
It would help your cause to post in the right forum, even though this is a general problem.
I second the alignment suggestion.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-11-2006, 11:20 PM
Eclipsewhipping Eclipsewhipping is offline
the convertibles always rattle and vibrate weird, mine does it and so does my friends.
