Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-11-2006, 05:01 PM
Mustafa_G Mustafa_G is offline
Is my E Choke Dead or something
I hooked my Edelbrock Carb up tot the battery and when I tried to start it and made a popping sound. It is now stuck open and I don't know why. was the battery to much juice or something.
Old 01-11-2006, 05:13 PM
Re: Is my E Choke Dead or something
now the stupid thing is closed and moving properly. So my question is what should I hook the 12V connector up to.
Old 01-11-2006, 07:43 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Re: Is my E Choke Dead or something
There should be a connection on the choke side. One wire (black) goes between the choke and the carb body. The other (red) hooks into your car's electrical system - a wire that's energized only when the ignition is on.
Old 01-11-2006, 10:10 PM
Will the windshield wiper motor due, and if so how do I identify which wire in the harness is the power wire?
Old 01-11-2006, 10:41 PM
silicon212's Avatar
Confoundingly Lucid
No that won't work, as that is only energized when the windshield wipers are on!
On my old '75 Grand Am, when I installed a Carter AFB on it (same carb, in fact the original to what you have), I tied into the blower motor on the A/C as it always ran whenever the engine was on due to the forced ventilation aspect of that car's A/C system.
What kind of car are you installing it on, what model year? I believe they used the forced ventilation from '71 through '79 - not sure on the last year as it might have been used into the 80s. Any car made from about '80 on should have come factory with an electric choke, if your car is newer than this you should already have the wire for the choke, just splice into it.
Old 01-12-2006, 05:48 AM
It is an 84 Caprice. I originally had it hooked th the wire from the old choke, but the car would not start. So I after tring a few things, I assumed that without those computer connections hooked up, the choke would not get any power. Is this correct. If not could you give me some other ideas of what to chec on why the car won't start.
It is an 84 Caprice. I originally had it hooked th the wire from the old choke, but the car would not start. So I after tring a few things, I assumed that without those computer connections hooked up, the choke would not get any power. Is this correct. If not could you give me some other ideas of what to check on why the car won't start.
